Rotel RB 1091 monoblock
pmckeealaska
pmckeealaska Posts: 808
edited July 2008 in Electronics
I was curious whether anyone on the forum has one of these bad boys in their system. I went into an A/V store in town yesterday and the salesman said that this thing puts out 1000 watts at 4ohms. It's a little pricey at $1500 but it sounds like it could really kick butt.
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
Post edited by pmckeealaska on
  • Gaara
    Gaara Posts: 2,415
    edited July 2008
    Never used that specific model, but have used amps that use the same module. If you were unaware those amps use the B&O 1000ASP module. Basically the module has everything you need for it to work, all the manufacturer does is throw it in a case and add some wiring.
    That said IMO the D-Sonics are a much better value at $1050 less for the same modules. A few members use those amps, Slowcar and Sheradp off the top of my head. I use and love EVS 500Ms which use the same modules, but they are modified for better performance.
  • miner
    miner Posts: 1,305
    edited July 2008
    I have the 2-channel version - RB-1092. This replaced a RB-1070. I am very happy with this technology. It has been compared side-by-side with a RB-1090 & Classe' CAP2100 integrated. The RB-1092 was the winner by the 'panel' reviewing. To surpass this amps capabilities would require spending 3X the $$$.
