psw450...????????location &setup
rnnwld064
hooking up my system and not sure where i should locate the psw450, or what settings i should be using, wife has tucked it away in the closet as we speak:supermad: , please help
Post edited by rnnwld064 on
Try the corner, if u dont like it there, Try the Center of the Main wall, just move it around and listen to see what sounds best to uDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
Speaks to small, LFE out to LFE in (unfiltered) at the sub. Corner placement. Calibrate all speaks with SPL meter."What we do in life echoes in eternity"
SVS -
What size speaks do you recomend Dr. Spec?
