Sub Problem
Jack M
Well today I got a box with 2 Boston 10.5 LF subs in them for free from my mechanic, however the outer rim and the woofer itself has fallen out a little big,
Hopefully you guys know what im talking about. How do I fix this or how much would it cost to fix.
THanks in advance.
THanks in advance.
Post edited by Jack M on
Are you saying that the sub itself is a little to small for the opening of the box?HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Here's a picture, the air is leaking out
You need new sub woofers that can not be repaired. Sorry for the bad news. That woofer it built into the sub when the are being molded. You might be able to contact the manufacture of the subs and see if they are under warranty.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
My friend says its the "suspension" that came apart, the woofer itself still works, but there is air leaking thru.
I understand what you are saying but unless its able to be rebuilt its done. Unless you can like with lacking bass. The "suspension" or cushion is what broke and they can not be fixed. The "foam" has deteriorated or been worked to hard.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Damn so theres no hope even to glue them myself?
On another note, the mechanic said today he would give me 12 inch brand new subs I just need to get a box first. How much would a decent box cost on the flea market or something? -
Ya the subs are done buddy sorry about that. Even if you glued it the vibrations from any bass will just rip it apart. A sub box for a couple reasons I wouldn't buy from a flea market unless you absolutely have to. You don't know the quality you are getting for one. I would buy one like this one. http://www.crutchfield.com/App/Product/Item/Main.aspx?g=178650&i=044QLH12D2&tp=554
At crutchfield you know you are getting quality.
Hope this works for ya and its in your price range.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Meh no worries, i got em free anyways lol now i just gonna throw them out -.-
but for that box u showed me thats well within my price range, where can i get one like that in the city, Do i need to go to a car speciality shop or what. I'm new to all this sorry if im asking dumbass questions.
What amp would you recommend? -
First off we need to know the model of the new subs you are getting so I know what power rang I should be looking for. Ya can get a box like that at best buy of circuit city or you can just order it right from crutchfield I have used them for quite a few years. You could go to a local shop but don't let them take advantage of you if you want to install it yourself you do it yourself just have them build you a box.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
I have heard that those Qlogic enclosures are not well sealed, so maybe you should try to put some glue on the corners befor you put your sub on it
and amps... well i think JBL kicker and Kenwood make some good products for the price, but im not sure, maybe someone more experienced can advise you betterZ
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
