outdoor sound system
i am thinking of purchasing 3 pairs of the Atrium 60's http://www.polkaudio.com/homeaudio/products/multiapplication/atrium60/
and i am wondering what the best receiver would be the perfect fit. should i find one that maxes out the wattage at 125 watts per channel. (yeah i like it loud) if anyone has a similar outdoor system i would love to know what type of receiver you use and if you would recommend it. and by "type" i mean brand and model #
thanks.
Receiver: Pioneer SC-05
Amplifier: B&K 125.2 S2
Floor Standing: RTi12
Center: LSiC
Front: RT15i
Sub1: PSW1000
Sub2: PSW350
Sub3: PSW505
"Any technology distinguishable from magic is insufficiently advanced."
Post edited by jp4smiles@yahoo on
  • Eric W
    Eric W Posts: 556
    edited July 2008
    Will this receiver be dedicated for the outdoor speakers only? Or do you plan on using it as part of a home theater, etc?
    -Eric
    -Polk Audio
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited July 2008
    My neighbor has a set of those outside and they are LOUD including the bass it rely sounds good. He is powering them threw zone 2 on his Onkyo TX-NR905.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • steveinaz
    steveinaz Posts: 19,546
    edited July 2008
    I run a cheap 'ol yamaha, 60 watts I think, I nabbed up for $40 bucks I think; with some energy C-3's on the patio. Sounds suprisingly nice. I don't want to put anything too expensive out there, dust/heat/ etc.
