Rear surrounds to match my LSiFX
pearsall001
pearsall001 Posts: 5,094
edited July 2008 in Speakers
I have the LSiFX as my side surrounds & I want to add a pair of rear surrounds. Due to placement constraints, another pair of LSiFX's just won't fit. If I remenber correctly Polk made another smaller pair of the LSiFX model. But I don't see it listed any more. What would match up well with them & not as big.
Post edited by pearsall001 on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited July 2008
    If the FXs won't work, you will have to go into another line. The LSiFX is the only surround and not much different in size than LSi7.
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    Could always get an earlier version of the LSi7 and remove the sides making them gloss black. I hear it looks pretty nice... :)
  • cheddar
    cheddar Posts: 2,390
    edited July 2008
    Guess it depends on what is the real limiting factor in size for the FXs. The LSi7 is definitely narrower and has a traditional bookshelf form. And it's lighter. I'd say it looks far less imposing and might pass WAF where the 4 driver FX that looks twice as wide might not. Also, if all you need is a timbre match but need it tucked out of the way, you might consider LCi in-wall/ceiling speakers. They have the same ring tweeter.
