Amp Help for a noob
ajsankot
ajsankot Posts: 141
edited July 2008 in Electronics
Hi guys,
I am pretty new to the speaker and sound thing. I always loved listening to music and only had a crappy box sony set. I got an internship this year which paid way better than a normal summer job so I finally bought a nicer pair speakers as well as got a pair of hand me downs from the folks. I also got a HK 146 for $132 and like it alot but it isn't the most powerful guy on the block.
So the question is.... I don't know much about buying and useing amps for interior use. Can you hook up an amp to a reciever like the HK146 and have it just give extra juice to the 4 speakers I have or how does and amp really work?
Definately a noob questions but I figured you guys would have a good answer
Post edited by ajsankot on
  • cfrizz
    cfrizz Posts: 13,415
    edited July 2008
    You can't use separate amplification with your receiver as it doesn't have preouts to do so.
    Receivers that do include preouts are much more expensive.
  • ajsankot
    ajsankot Posts: 141
    edited July 2008
    Ok, cool. thanks for the answer man
  • ajsankot
    ajsankot Posts: 141
    edited July 2008
    A moderator may remove this post if they would like. Question answered
