ground loop? noise from only rear set?
ilikesound
ilikesound Posts: 355
edited July 2008 in Car Audio & Electronics
I've got the mmc690's in the rear of my car right now, and i'm getting some hum from the rears only. it's odd, because i'm running those AND a pair of the mmc6500's in the front, off the same amp (c400) I don't get the noise out of the fronts. nor the sub. I am going through a ground loop isolator on the rears, which seems to dull it down a bit, but it's still there. My grounds are ok, and everything looks in order, i just can't track the source down! Anyone have any other ideas?
At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
Post edited by ilikesound on
  • [Deleted User]
    [Deleted User] Posts: 0
    edited July 2008
    Try connecting a new set of RCA cables from your HU to amp. Just hang them over the seats for troubleshooting. Or try swapping F/R RCA's see if the problem moves to the front.
    Len
  • Jstas
    Jstas Posts: 14,999
    edited July 2008
    Len has a good point. I had a similar problem with my front, right speaker. I replaced drivers and such and nothing changed it. Then I pulled the head unit out and checked the RCA's and sure enough, the right channel's ground lead was pulling off of the collar. Swapped out cables and the noise went away.
    You might also have it pinched somewhere. You don't need to break the insulation to cause signal interference. Electricity can be a funny thing some times.
    Expert Moron Extraordinaire
  • ilikesound
    edited July 2008
    thanks guys, i'll try that tomorrow and re-post my findings!
    At Home:
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Away From Home:
    JVC HDR-50
