Adcom GFA-555 Modded, and gone through
ben62670
ben62670 Posts: 15,969
edited July 2008 in For Sale (FS) Classifieds
Well I have another piece to go. This one is an Adcom GFA-555 with all new electrolytic caps, bridge rectifiers, drivers, cap mod on top of main filter caps, and better power cord. The PS cap mod is small 12uf caps on top of the main PS caps. Big computer caps aren't as smooth as the smaller ones, and many guys add these to clean up the highs.
$400 shipped with a pair of Silver IC's
I'll post pics later
Ben
Ben
Post edited by ben62670 on
  • ben62670
    edited July 2008
    Bump for the evening crowd.
    Ben
  • george daniel
    george daniel Posts: 12,096
    edited July 2008
    I can't believe this is still sitting here,,especially with people looking for amps to power newly aquired speakers.Good luck with the sale Ben.
  • Systems
    Systems Posts: 14,873
    edited July 2008
    How much power does this have Ben? 8ohm & 4ohm? Bridgable and stable at low ohms ?
    Chuck
    pssst....its a bump too.
    Testing
    Testing
    Testing
    heiney9 Posts: 25,165
    edited July 2008
    Chuck
    200 wpc @8
    350 wpc @4
    will run admirably into a 2 ohm load
    Stable into low impedance when bridged (except a no..no.. with SDA's when bridged)
  • Ricardo
    Ricardo Posts: 10,636
    edited July 2008
    This is a great amp, and with new caps it will last 20 more years.
    Someone needs to grab this, soon.
    SOPA
  • ben62670
    edited July 2008
    The mods don't add any power. They tighten the bass, clean up the mids, and highs. Thanks guys for the props. This amp is definitely sweeter than a stock 555.
    Ben
    Ben
  • ben62670
    edited July 2008
    Guys modded. Not stock. Gone through. With IC's. Ebay is going to get it soon.
    Ben
  • george daniel
    edited July 2008
    With all the people posting questions about their newly aquired SDA's and need for an amp,this is a no brainer.This amp will have you covered,if this goes to Audiogon,it won't last one day I tell you,one day.Good luck with the sale Ben,,I can't believe that its still here.
  • ben62670
    edited July 2008
    Thanks George.
    I'll sell the amp without IC's, and you guys pay shipping for $300
    Ben
    Ben
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2008
    Any pictures?
  • schwarcw
    schwarcw Posts: 7,338
    edited July 2008
    I think if Adcom added meters to their amps they would sell a boat load.
    Carl
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited July 2008
    Adboms are cool. I've had 2 555's modded to near 800w cont on the bench.
  • ben62670
    edited July 2008
    RuSsMaN wrote: »
    They must have beefed the toridal? Is that each channel, and at what ohms?
    Ben
    Ben
  • RuSsMaN
    edited July 2008
    Dual power trannies, much higher voltage on the rails (obviously) all per channel, continuous at 4 ohm. We ended up setting fire to both on Danny's Alpha Line Source (a speaker you cannot blow up).
    Cheers,
    Russ
  • ben62670
    edited July 2008
    RuSsMaN wrote: »
    Cheers,
    Russ
    Don't encourage me. I have a spare 555 tranny on the shelf!
    Ben
    edited July 2008
    RuSsMaN wrote: »
    Cheers,
    Russ
    There are several hobbyist's that are very knowledgeable about circuit design, etc over at DIYaudio that run the **** out of their Adcom's. It's a very robust design right out of the gates and I know several people who run them "hot" w/o issue. But you've got to have some working knowledge to keep from destroying things.
    The best testament is when Stereophile took an Adcom 555 II and ran the Scintilla speaker, which dips below 2 ohms, to a very commendable level w/o the 555 II even hiccuping. They were using the factory supplied fan system and IIRC, they put slightly higher rated rail fuses in.
  • ben62670
    edited July 2008
    Sold
    Ben
  • Systems
    edited July 2008
    Good for you Ben.
    Chuck
    Testing
    Testing
    Testing
  • george daniel
    edited July 2008
    Hopefully someone here picked it up,,I just felt compelled to say that.;)
