Kingston's "Value" RAM
jakelm
jakelm Posts: 4,081
edited August 2008 in Electronics
Should I be embarassed? I use it.. Who else does? I'm thinking of switching to something more "rich" sounding.:p
Seriously, DIMM DDR 1g 400mhz 184 pin./. I cant think of anything better to use for the money.
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
  • steveinaz
    steveinaz Posts: 19,546
    edited July 2008
    Chips on a board--Back when I built all of my computers, I used good name brand memory, but I didn't pay the Kingston price.
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    steveinaz wrote: »
    You find Kingston expensive? From experience I find the pretty reliable. I couldnt tell you about performance though, never compared.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    Maybe I should spend alittle more on something like this
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • steveinaz
    edited July 2008
    Keep in mind, my last build was about 7 years ago--I'm RUSTY. I think I have some cheap Sanyo memory in my computer, and oh yes--she's still runnin.
  • Marty913
    Marty913 Posts: 760
    edited July 2008
    jakelm wrote: »
    Actually, two of the others on that page (Corsair & OCZ) are probably better buys but I have absolutely nothing against Kingston. I am currently using 4GB of GSkill which I have found to be the best memory (DDR2) for the money. I've used it in my last several builds. Never has failed me.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    Marty913 wrote: »
    I hear different stories about mixing brands of RAM
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    Corsair. I am running G-kill too. Pain to tweak. I should have stuck with Corsair.
    Ben
  • Marty913
    Marty913 Posts: 760
    edited July 2008
    jakelm wrote: »
    I have never found it to be a problem as long as the specifications are the same. Back in the early days (pre-DDR) it certainly was and motherboard chipsets were a lot less forgiving. If you're using DDR then mixing memory brands is not a problem.
    TT = Audio Technica
  • dylanblada
    dylanblada Posts: 77
    edited July 2008
    Kingston used to be expensive, now they have a little of everything (like all the other brands). Truth is, as long as you're not overclocking, or running business server, there is no need to spend any more than the cheapest RAM.
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    dylanblada wrote: »
    I'm an overclock nut though (well, I try to be), but pretty much stick to just overclocking the CPU.
    My little Athlon 4200 x2, 2.2 is currently running @ 2.7
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2008
    Im a little rusty myself, still running an Athlon 3200XP with 2 GB Corsair Ram. Dell has gotten so cheap, Im not even sure I will build my own rig again. Though I do find it fun to sit down and put one together.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2008
    I did a new build last feb and in4 months I had 5 RMAs on the crucial balistix 1066 so I swithced to OCZ 1200 and havent had a problem since.And I have the core2duo E8400 overclocked to 3.6GHZ.And the EVGA 8800(G92) at 750/1675.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • dylanblada
    edited July 2008
    Even if you are OC'ing, OCZ. for instance, makes some really good, cheap RAM for it with good timings. And if we're taliking DDR2 here, most RAM is SO cheap it'd be ok to spend another $10-$15 for decent RAM.
  • GEBBY44
    GEBBY44 Posts: 939
    edited July 2008
    Tried em all - Corsair, Kingston, OCZ - and if you plan on doing any overclocking, the best value I've found is Patriot. With all the rebates and crap, you can usually get it for cheaper than those others. It's reliable as hell and works great in my oc'd quad core setup. I've also heard g-skill is good too, though I've never tried it.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited July 2008
    i use ocz and nothing but ocz
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    I shop at newegg, is there a cheaper store? Geeks.com maybe?
    Kingston has really never given me any problem, but like someone posted earlier, being I DDR and not DDR2, mixing brands shouldnt be a problem. Might give OCZ a try, I still cant find Patriot, in 184 Pin DDR 400mhz.
    But since I have the cheap Kingston in the system already, i dont know how much good it would do to mix it with more expensive RAM.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    Excuse the ignorence, but, what is Cas Latency?
    And what would all do, 1 stick of 1g or 2 sticks of 512?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • fbm211
    fbm211 Posts: 1,488
    edited July 2008
    Join toms hardware forum and you will find the exact translation.The lower the number the better/faster ...However with todays faster DDR3 (mhz) memory it doesnt matter as much as it used to.Use two sticks for dual channel. I have two sticks of OCZplatinum PC3200 dual channel DDR I could sell you if your interested.(2x512mb) timings 2-3-2-5
  • Marty913
    Marty913 Posts: 760
    edited July 2008
    jakelm wrote: »
    Patriot is a relatively newer brand (DDR2 & up) so I don't think you'll find plain DDR there. If I were you, I'd go with Kingston Value, same specs as your current DDR, and get it as cheap as possible. It will not be reusable in any future machine you buy or build.
    TT = Audio Technica
  • kuntasensei
    kuntasensei Posts: 3,263
    edited July 2008
    I used to build my own systems, but when my Athlon 3200+ rig died last week, I just couldn't face it. Since I got my Xbox 360, I haven't been into PC gaming so I didn't really need a monster rig... so I snagged this sweet deal.
    Quad Core 6600, 3gb of ram , 720gb of hard drive space, Nvidia 8500 GT, NTSC/ATSC TV tuner, Vista Home Premium 32-bit and a free 24" LCD monitor. Been playing with it for the last two days - works like a champ. Yeah, that HD-DVD drive they include is nigh worthless... but with the HDMI output, I could swap out for a Blu-ray drive later and make a decent HTPC out of it.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • VSchneider
    VSchneider Posts: 443
    edited July 2008
    Jake, if you are only upgrading RAM for your Athlon (which can only take DRR, right?) you want two identical (or at least with compatible latency numbers) sticks to run dual-channel with the lowest Cas Latency (CL - the first number in the specs). I am using a par of CL2 Corsair with my AMD 4200.
    If you want to overclock something other than the CPU, your memory quality starts to matter, too.
    The Value RAM runs at 400 MHz and CL3, and if you push it faster it will likely begin making errors, where a "more expensive sounding" RAM may just heat up but still work.
    - Val
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    I'm just going to get the same thing I have now.
    Question: 2 sticks of 512 or 1 stick of 1g?
    Thanks for the help.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited July 2008
    Does your puter do dual channel? I still prefer pairs if not.
    Ben
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    ben62670 wrote: »
    Ben
    My puter does 4channel, I have 2 512 in right now
    That leaves me 2 channels, I was going to stick 2 1g's in there.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • WilliamM2
    WilliamM2 Posts: 4,811
    edited July 2008
    jakelm wrote: »
    He is referring to dual channel memory. You need the same ram config in each channel to do that.
  • ben62670
    edited July 2008
    Not slots, but channels;)
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited July 2008
    WilliamM2 wrote: »
    Sorry head not working today.
    And just think..I build these things...lol
    So I could not use 1g and a 512 in A1 and A2?
    And a 1g and a 512 in B1 and B2?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • concealer404
    concealer404 Posts: 7,440
    edited August 2008
    Marty913 wrote: »
    Patriot's been around for years. I still have PC3200 sticks running around in a AMD Mobile 2500+ rig at 2.9ghz on air. Some of the best ram ever. Holds lower latencies longer than my tried and true Crucial Ballistix, although the Ballistix will go to a higher overall clock.
  • WilliamM2
    edited August 2008
    jakelm wrote: »
    Sorry, missed this post. Yes you can. Like I said, each channel, or pair of channels must match, and that would work.
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    I went with 2 more 512 KVR. But my system seems sluggish for some reason. To open a web page or to go from one page to another, sometimes I have to click 2 or 3 times. It never happened like this before the new RAM, I wonder if its the sticks or just coencidence. The new RAM sticks are excatly the same as the old. And the system is reading 2g's correctly.
    I also had a question why the RAM is stuck at 200mhz, when the RAM specs show to be able to go to 400mhz? Can someone explain if I can boost or change the MHz to something faster?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
