Secondary 2 ch setup for analogue
I will be doing a separate 2 ch setup for my Rega P7. Rotel RC-1070, RB-1070 pre and amp. I need to add speakers. Torn between monitors and floorstanders. I prefer to forgo a sub at this time. I am thinking the LSi9 will be a good choice. How is the bass response on these? The music will not be played at insane volumes - this setup will be used for more critical low-level listening. What is a good price for 'new' LSi9s? And, can you recommend a good quality stand to use with them? Other speakers I have been eyeing have been B&W, Vienna Acoustics, and Totems.
Post edited by miner on
LSi9s are good speakers, but only have the bass response and output of a bookshelf style speaker. I don't mind listening to bookshelf speakers without subs, but a lot of people do. You could jump up to the LSi15 and increase the bass response quiet a bit if you have room for the floorstand.
Have you considered Martin Logan?2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
It depends on the room.
In a small room, you may be able to get by with 9's and no sub."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
