New PSW1000 dead in 1 minute
BLACKHAMMERJAMM
BLACKHAMMERJAMM Posts: 69
edited August 2008 in Speakers
New PSW1000 dead in 1 minute? I Have 2 of these and the older one works fine, but the new one had a short life. It still powers on and lights up green when a signal is present but no output? I tried all the switches and still no sound. Am I missing something?
Sony KDL-52XBR4
Onkyo Pro PR-SC885P
NAD T975
LSIi15's front
LSIiC center
LSIiFX's surround
LSIi15's rear
PSW1000
Sony BDPS2000ES
2nd system
Sony STRDA5300ES
Sony PS3
LSi9's front
Klipsch sub
under construction
Post edited by BLACKHAMMERJAMM on
  • danger boy
    danger boy Posts: 15,722
    edited July 2008
    does it have a fuse? if so.. pull it and check to see if it blew when you turned it on.. it's possible that it did.
    PolkFest 2012, who's going>?
  • BLACKHAMMERJAMM
    edited July 2008
    danger boy wrote: »
    Fuse is OK, the unit still has the power indicator light on.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • BLACKHAMMERJAMM
    edited July 2008
    anonymouse wrote: »
    Were you driving it hard? Its possible (though improbable) that a connector that was working loose in transit finally came loose - most likely the connector that hooks the amp to the subs. If you know what you are doing, you can remove the plate amp and take a look inside.
    Thats possible.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • zingo
    zingo Posts: 11,258
    edited July 2008
    I would poke around inside as mentioned before and see if it is something simple. Did you say that the sub is new and had only been on for 1 minute when it stopped working?
  • BLACKHAMMERJAMM
    edited July 2008
    zingo wrote: »
    1 minute, yes. Opened it up and checked all the connections. Nothing is loose or unconnected. The speakers do hum when I remove the RCA cable. I think I will just send it back.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
    treitz3 Posts: 19,950
    edited July 2008
    Mr. BHJ, have you tried to hook it up to a known working RCA out that works [hookup while unplugged] that leads from one of your sources? [CDP, DVD, LP, etc....]
    If you have not, test with the volume ALL of the way down on the sub and slowly work your volume up on the sub. If you have sound coming from the PSW1000, then it is not the sub. Try this, if you will and then get back to us please.
  • BLACKHAMMERJAMM
    edited July 2008
    treitz3 wrote: »
    I have 2 PSW1000's, so I tested the broken one by using the RCA out that is normally connected to the working one. I tried the volume thing and just about all the switches. I still could be missing a test or 2, so any suggestions are much appreciated.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
    edited July 2008
    Edited.
  • BLACKHAMMERJAMM
    edited July 2008
    Returned to Polk for Replacement. I will update return-replacement status and turnaround time. Hope it doesn't take too long.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2008
    How much did it cost to ship that heavy beast?
  • BLACKHAMMERJAMM
    edited July 2008
    BlueFox wrote: »
    About $200 from my pocket.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • BLACKHAMMERJAMM
    edited July 2008
    It's now at the Polk service center...Just waiting for someone to open it up and check it out.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • garnier
    garnier Posts: 116
    edited July 2008
    This is not about your PSW1000 subwoofer, but about your Sony BDP-2000ES.
    I have a BDP-S1 instead, and noticed that if I am watching a PCM source like uncompressed PCM, then it sounds louder and better if I put the audio setting of a blu-ray player at PCM. Likewise, if I am watching either a Dolby Digital, DTS, DTS MA, or Dolby TrueHD sources, then it sounds louder and better if I put the audio setting at Auto (sending out audio codecs as bitstreams for a receiver or a pre-amplifier to do the decoding instead). Have you noticed that difference or is it just me? It is combersome to switch the setting back and forth depending on the sources, but I do seem to notice the difference in sound qualities between the settings and the audio sources. :confused:
  • BLACKHAMMERJAMM
    edited July 2008
    garnier wrote: »
    I will check later tonight, I think I'm set on auto?
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • BLACKHAMMERJAMM
    edited July 2008
    It sat for one day and then was fixed. Color didn't match the rest of my other speakers so they looked for a new one to match the newer production PSW1000's. tomorrow Polk service will ship me back a new sub. So far I call this as great customer service.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • BlueFox
    edited July 2008
    Maybe there will be 2 one hundred dollar bills in the return box to cover your shipping. :)
    Good luck. I love my LSi15s and PSW1000.
  • BLACKHAMMERJAMM
    edited July 2008
    No $200 in the box with the new PSW1000.... Well at lease this one makes noise, but the damn volume control is broke... The people at the service center did a great job, but someone needs to check quality control. This sucks!!!
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • BlueFox
    edited July 2008
    Will they pay for shipping this time since the service center should have noticed the volume control doesn't work? Did you notice the volume control goes to 11? :)
  • BLACKHAMMERJAMM
    edited July 2008
    I hope so.. oh I just noticed that 11... I don't want a PSW1000 at all, hopefully I can trade it in for a MicroPro 3000 or 4000. The PSW1000 has way too much port noise (even if you take off the power port plate). I compared my Klipsch sub-12 to the PSW1000 and at half the cost the Klipsch was better for loud HT use. For music and low volume HT the PSW1000 is better.
    for now I have to wait till Gill gets back from vacation to find out about the trade.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • BLACKHAMMERJAMM
    edited August 2008
    Gill got back, took care of my request and will be sending me a new MicroPro 4000. WOW that is great service and I don't even have to pay for shipping back this time.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    Sweet. Polk CS rocks!
    Ben
