Is it even possible??
TonyR
Guys and Ladies I am seeking wisdom and knowledge.I have a Yamaha Z9 receiver and an HP pc. Is it possible to connect the two so that i can listen to down loaded music or watch movies that are on my hard drive through my home theatre? What cabling would I use neither have an HDMI connection?
Tony
Tony
Yamaha rx z9
Rti 10's front
A6 center
(2) Psw 505 subs
Rti 10's sides
Rti 6's backs
Rti 10's front
A6 center
(2) Psw 505 subs
Rti 10's sides
Rti 6's backs
Post edited by TonyR on
You have to find inputs/outputs that are in common. Your sound card will have some type of output, most have analog 3.5mm stereo and some have digital outs too. Your video card may have DVI, which could be converted to HDMI. Do some research either online or in documentation to determine your options.
DGHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
If your PC has a 3.5mm jack, you can use a 3.5mm to RCA adapter. But if you have an optical out on the HP PC, you can run an optical cable between the PC and the receiver.
My HP z560 Digital Entertainment Center has an optical, coax, and analog out. If your HP was made within the last few years, it should have some kind of digital out - that would be your best choice.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Thanks very much for the info.Yamaha rx z9
Rti 10's front
A6 center
(2) Psw 505 subs
Rti 10's sides
Rti 6's backs
