2000 silverado blow through sub box
mr.atnt
well, this is my first post. I need help with a blow through box. I have (4) 12" subs that are going in a tool box that will be mounted right behind the cab. They will be firing straight out. Where do I buy the rubber boot? Is there a kit a can buy some where?
Chris
Chris
Post edited by mr.atnt on
Chris -
Welcome to the forums. I think you'll be better served if you go to the 12V side of the forums. Look for the car audio section.
ChuckTesting
Testing
Testing
