Omfg!
Shannon W.
Guys I finally watched the movie "Sick House" and I had the little system at normal listening setting (-30) and there is a scene where one of the punk kids (Shawn or Steve) puts his hands on one of the brick walls and OMFG, I thought my PB12+2 was Phucked up. I had my SMS-1's volume set on 23 which is only a little bit over the factory setting of 18 and when she started pounding I seen the draw on that outlet hit 10.5 Amps. Its only on a 15A circuit. Is there a equation that I can use to find out how much power the amp on the sub was putting out with that kinda load.
The sub never bottomed out but it had to be damn close. Needless to say After I was like (Oh ****) I turned the volume on the SMS-1 down to 18 again.
The gain on the sub amp is set at just a little over the first notch so its not turned up hardly at all. Also i have two ports plugged off and set to 16hrtz.
One more thing what do most of you guys that have the PB12+2 run the gain on the amp at?
Shannon
Shannon
50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Post edited by Shannon W. on
Watts = Amps X Volts.....................if you are getting 120 volts, your system was pulling 1260 watts during that peak.
Of course, this doesn't account for the loss of wattage due to heat, loss of efficiency, etc. just the amount of load in watts passing to your gear. Your electronics can't convert all that wattage into power due to those losses.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Now I'm gonna have to rent that video and watch it. I love lots of low bass action. I don't have an answer for your question, but I'm curious how you like the SMS-1. From what I've read on-line it seems very useful and the idea of having cleaner bass is something I'm interested in. A quick check on the 'gon shows they cost around $500. Give me your opinion about it.
theres a thread on the SMS-1. A few more of us have them, especially useful with dual sub setups also. I highly recommend one, they seem to maxmize sub performance. I'll have to check that video out, should be insane with two of those PB12+2s going at it.Shoot the jumper.....................BALLIN.............!!!!!
My SMS 1 is set at 7 for the 80DB run, my +2 gain is about 9 oclock and i turn the SMS up when i think i need it. I have 16HZ, port plug and not sher if i like it better then 25HZ or not. I know i lost all the booomy bass and people not in the know would probley say where did all your bass go. But its much more blended and clean sounding. I can still shake the hole house if i want but it happenes when its supose to happen insted off just pure caose. and no i did not spell check thisRTi12's:D
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
PHILLIPS 42" PLAS. 1080i
Monster 5100 SS -
Dennis Gardner wrote: »Watts = Amps X Volts.....................if you are getting 120 volts, your system was pulling 1260 watts during that peak.
I know why that didn't sound right (My .A draw) the Plasma pulls 2.2A alone. Also that outlet shows 121V to 125V. So at the time it showed 125V X (lets say) 8.5A = 1062.5W +/- what ever the heat loss.
Also if the Bash plate amp is 900W RMS dose that mean it (In theory) should do 1800W max?
One more question Would it be better to turn the SMS-1 down and the gain up or just leave it alone. I never could get a flat sub response (Bad room placement but it was ether where it is now or on the same side of the room but right beside the listening position.
Shannon50" Samsung Plasma
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig -
I luv my SMS-1 I just now wish I would have not got the SVS PB12+2 due to not needing the PEQ with having the SMS-1. I wish I would have bought 2 of the PB12-NSD/2 for a few more $$ and had Dueling SVS'S.
But to let you know also I bought my SMS-1 off eBay for $425 shipped NIB from a Velodyne dealer and I got a full warranty. If you want I can try and find the guy that I bought it from and PM it to you.
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Guy I know that this was not the right place for Movie recommendations, but I Highly recommend that movie. It will give any sub a good work out.
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
just get one more plus 2RTi12's:D
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
Monster 5100 SS -
Shannon W. wrote: »I luv my SMS-1 I just now wish I would have not got the SVS PB12+2 due to not needing the PEQ with having the SMS-1. I wish I would have bought 2 of the PB12-NSD/2 for a few more $$ and had Dueling SVS'S.
Shannon
Thanks, but I'm seriously considering buying the used one in the Flea market.
