sub crossovers
rednks1
i have 2 psw 1000 without the amps i am wanting to drive them with a carver
amp and need help finding a crossover to put in the subs if any one has any sugestions or help on finding or building a crossover to mount in place of the plate amps it would be very helpful thanks
onkyo 805
rti8 front
csi3 center
fxi3 surounds
rti4 back surounds
2 carver m1.0T fronts
and subs
5-marantz ma 500
110" screen
mits 1500hc
2-psw1000
rti8 front
csi3 center
fxi3 surounds
rti4 back surounds
and subs
5-marantz ma 500
110" screen
mits 1500hc
2-psw1000
Post edited by rednks1 on
Reckhorn B-1.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
nice unit but it looks like it only comes at 230 voltsonkyo 805
rti8 front
csi3 center
fxi3 surounds
rti4 back surounds
and subs
5-marantz ma 500
110" screen
mits 1500hc
2-psw1000 -
Might be kind of obvious, but do you really need a crossover? Why not just hook the sub up to the LFE out on your AVR and use the crossover built into the AVR? (one of my subs is passive with no crossover and it works great that way)
Edit - sorry, meant hook your Carver up to the LFE out on your AVR and hook the speaker outs on your carver directly to the woofers in your subs? (might want to put some binding post plates in place of the amp hole. Get some decent binding posts, and you are done...)Mains.............Polk LSi15 (Cherry)
thought about that but the fine tuning would be nice and yes i will put plates with binding posts but will make them my self have the luxery of a machine shope at workonkyo 805
rti8 front
csi3 center
fxi3 surounds
rti4 back surounds
and subs
5-marantz ma 500
110" screen
mits 1500hc
2-psw1000 -
If you would normally use the LFE the crossover dosnt matter anyway because the LFE bypass the crossover. I second McLoki just use the avr.If life had more tubes it would be a lot smoother.
No. Buy it here: http://www.creativesound.ca/details.php?model=B-1HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Personally I would just hook up the speakers through the LFE and if you want the ability to fine tune, put about $85 twords a BFD. (I have one and its great)
thanks guys both units look good but i think i will try the Reckhorn B-1 with a carver m1.5t to power both psw1000 and see what she sounds likeonkyo 805
rti8 front
csi3 center
fxi3 surounds
rti4 back surounds
and subs
5-marantz ma 500
110" screen
mits 1500hc
2-psw1000
