How Far Apart?
Sansui
Sansui Posts: 372
I'm going to be adding back surround speakers to my system. Thanks to Face I know how high they should be but I can't find anywhere in Polk's documentation how far apart they should be.
Right now my three front RM202's are at (couch) listening level and my two surround RM8's are 38" high using Polk's SA3 speaker stands.
I'll be using my other two RM101's against the back wall and 60" apart (30" off the center line of my living room for each).
Any suggestions?
Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
Post edited by Sansui on
  • zingo
    zingo Posts: 11,258
    edited July 2008
    I would try placing them no less than the distance that your front speakers are apart. I have always placed them a little wider than the fronts, but it's all trial and error.
  • Sansui
    Sansui Posts: 372
    edited July 2008
    zingo wrote: »
    Thanks! I'll give it a try.
  • zingo
    zingo Posts: 11,258
    edited July 2008
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2008
    Well, actually, before he defected, Polk Paul recommended the Back Surr. be closer together, I would move them around a bit (if possible) and see what you like. Since Paul is gone you could contact Ken Swauger for the details.
    RT1
  • danger boy
    danger boy Posts: 15,722
    edited July 2008
    i would say... 6ft and/or more would be good for surround speakers. mine are just over 9.0' apart
    PolkFest 2012, who's going>?
  • Sansui
    Sansui Posts: 372
    edited July 2008
    Thanks for the replies. I'll call Ken and then probably end up moving them depending on what he says.
