Need Help Configuring My Subs
rumbatinio
Hi guys i just installed some subs for my car i mean i didnt installed them but a guy in bestbuy did because im really not good at this and now i have some questions i hope you can answer because im not so happy at the result im getting so far
Ok so this is what i got
2x --> http://www.bestbuy.com/site/olspage.jsp?skuId=7057383&type=product&id=1108124880979
1x --> http://www.bestbuy.com/site/olspage.jsp?skuId=8699367&type=product&id=1199494646259
1x --> http://www.pioneerelectronics.com/PUSA/Products/Navigation/In-Dash/AVIC-D3
So my question here is after the install you know everything works well and it bumbs but some times i have kind of clipping noise and i hear more of a deep base like buuuuuuum than just a single bump that should vibrate my car so i want to get to the point were i want to enjoy the music and just get that bump more than the continuous bass and clipping noise and to get to the result i think i have to configure my amp and i have 3 options
Gain --- >
Bass EQ -->
LP Filter -->
If you guys can tell me how to put all those to the right point to match my Subs and Head Unit its going to be greattttttttt
Thx for your time !!!
Gain --- >
Bass EQ -->
LP Filter -->
Post edited by rumbatinio on
turn them all as high as they go
