Time Delay
billz428
billz428 Posts: 45
edited July 2008 in Car Audio & Electronics
I could some help getting mine right.
HU- Alpine CDA-9813
Amp- Alpine MRVF 357 5ch 40x4- 120x1 sub
Front Speakers Polk DB6750 - 6 3/4 componants
Rear Speakers Polk DB460 - 4x6 coaxial
Sub Polk -MM2104 10in sealed encloser
This is in a 1998 ext-cab Pickup all speakers in factory locations.
RF- 60in.
LF- 42in.
RR-48in.
LR- 30in.
These distances are from speaker to center of driver seat where my head is located:o..
Any help would be great, Thanx
http://www.cardomain.com/ride/3228763
Life is tough. Life is tougher when you're stupid.
-John Wayne
Post edited by billz428 on
  • frosty2k
    frosty2k Posts: 39
    edited July 2008
    billz428 wrote: »
    RF- 60in.
    LF- 42in.
    RR-48in.
    LR- 30in.
    Well, according to my HU manual, the equation for timing setting is:
    A = (B - C) / 34
    A: Delay time (ms)
    B: Distance from listening position to furthest speaker (cm)
    C: Distance from listening position to the speaker to be adjusted (cm)
    Essentially your farthest speaker would be offset at 0.0ms and everything else is 'pushed back' from you listening position. If you have a sub that is farther than your RF speaker, that should be 0.0. You will have to convert the distance to centimeters also or else this function will not work. I dont know the one for inches.
    I'm too busy at work right now to do the math for you too. :p
    /////ALPINE INA-W900 HU
    /////ALPINE PXA-H100 DSP
    polkaudio SR5250
    JL Audio HD600/4
    polkaudio SR124DVC
    JL Audio HD750/1
    "In this house, we obey the Laws of Thermodynamics!"
  • billz428
    billz428 Posts: 45
    edited July 2008
    Cool!!
    1in=2.54cm TD is Time Delay
    RF-60in=152.4 TD=0.0
    LF-42=106.68 TD=1.34
    RR-48=121.92 TD=.89
    RL-30=76.2 TD=2.24
    A = (B - C) / 34
    A: Delay time (ms)
    When you get a chance please check my math:o.
    Thanx for your help.
    -John Wayne
  • Greg Peters
    Greg Peters Posts: 605
    edited July 2008
    For the "easy way" to set up the time alignment, sit in the driver's seat, select a mono source (AM radio) with talk radio, enter the T/A function...slowly add delay incrimentally to the left front channel until the spoken voice clearly sounds like it's coming from dead center in the dash (or dead center in front of your listening position if you prefer, but some feels this mucks with staging).
    BTW- I had a 9813. Nice head unit.
  • frosty2k
    frosty2k Posts: 39
    edited July 2008
    billz428 wrote: »
    Looks right to me. You will find that Greg is also correct. This calculation is just a solid starting point. After I set mine using the math, I moved them + or - a few increments to adjust them how they sounded best.
    Your head is almost never exactly where you measured all the time.;)
    polkaudio SR5250
    JL Audio HD600/4
    polkaudio SR124DVC
    JL Audio HD750/1
  • billz428
    billz428 Posts: 45
    edited July 2008
    Thanx Guys.
    -John Wayne
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2008
    Check out Alpine's i-personalize on their website. Plug in all the measurements and itll give you some very good starting points.
  • billz428
    billz428 Posts: 45
    edited July 2008
    Thanx Macleod, made it way easy.
    -John Wayne
