DeoxIT® GOLD ProGold
MKZ
http://store.caig.com/s.nl/sc.2/category.292/.f
Where do you get those other than caig.com? AudioAdvisor has it but limited. And which one like brush or pen or spray? Thanks.
Post edited by MKZ on
I've seen them at Radio Shacks; try also Partsexpress.com
Edit; for me, brush is easier to apply._________________________________________________
Thank you Ricardo. RadioShacks has brush also? I found only spray on their site.
In store, I've only seen the spray.
Parts Express has a good selection.
http://www.partsexpress.com/webpage.cfm?FILTER=deoxit&FTR=deoxit&search_type=main&WebPage_ID=3&x=0&y=0
The brush and needle dispenser are the easiest to use, but the spray does come in handy sometimes."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Thank you all, one more dumb question. Can I just use the Conditioner alone Or DeoxIT® - Contact Cleaner & Rejuvenator 1st and then
DeoxIT® GOLD - Contact Enhancer, Conditioner & Protector? -
I use option #2.
