Onkyo 805 and PS3
edossin4
I have the PS3 hooked up with the HDMI cable and that connection is selected on the PS3 menu.
Whenever I play a disc on the PS3; Blu Ray or game, the window on the Onkyo says 'multichannel'.
When I play a DVD on my OPPO the window says 'Dolby Digital' or 'DTS'.
It sounds alright and I am getting surround but I don't know if something is not set up right.
I want to get the best sound out of the PS3.
Onkyo Tx sr805
Oppo Dv-981hd
Onkyo Dv cp704
Adcom Gfa 555
Adcom Gfa 545
Polk Audio rti 12
Polk Audio cs400i
Polk Audio fx300i
Panasonic 54" rear projection
Direct HDTV DVR
PS3
Oppo Dv-981hd
Onkyo Dv cp704
Adcom Gfa 555
Adcom Gfa 545
Polk Audio rti 12
Polk Audio cs400i
Polk Audio fx300i
Direct HDTV DVR
PS3
Post edited by edossin4 on
It sounds like you have the Ps3 set to do the decoding and output multi-channel. Just a thought.
The display is correct... the PS3 is doing the decoding and sending the signal as a multichannel output to your receiver. The PS3 cannot send the unencoded signal to a receiver.
What is the purpose of the "bitstream" option on the PS3? I am not using HD audio yet anyway, but I thought "bitstream" sent the unencoded audio track. -
So I guess that means everything is peachy! Thanks.Onkyo Tx sr805
Oppo Dv-981hd
Onkyo Dv cp704
Adcom Gfa 555
Adcom Gfa 545
Polk Audio rti 12
Polk Audio cs400i
Polk Audio fx300i
Direct HDTV DVR
PS3 -
What He is seeing is correct. The only time you want to use bitstream is for SD DVD's.(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
(2) Panny DMPBDT110 3D Standalone Players
Panny 60" 3D Plasma TC-60ST30
Panny 50" Plasma TC-P50G10
Panny 50" 3D TV TC-P50GT25
Denon AVR-891
Harmoney One Remote
Polk Monitor 70's,Polk CS2, Polk Monitor 40's -
The ps3 is just as capable of bitstreaming DD or DTS as the oppo. You just have to choose bitstreaming instead of PCM in the appropriate menu. The only limitation to bitsteaming occurs with new blu-ray formats such as TrueHD and DTS-HD MA lossless audio. The only alternative is to decode these in the ps3 and send them out as PCM which reads as multichannel on the onkyo. You are getting the full benefit of the lossless tracks when you have it configured this way, just as if the onkyo decoded them internally.
Not sure if the 805 suffers from this, but on my onkyo pre, it failed to provide the necessary 10db boost to the lfe channel when reading multichannel. The lfe channel is purposely added to the audio track at -10db to prevent overloading the input path since lfe is so much louder than the other channels. When the processor receives bitstream, it automatically boosts the lfe bass 10db. Some processors, however, don't automatically boost the bass when reading multichannel. So if the bass seems thin, you'll need to boost the bass on the lfe channel manually by 10db. But you might have to play around with the different bass settings for different inputs to find the least painful way of configuring this.
(I think my onkyo only allowed -10db settings not +10db settings. So I did something like boosting the general lfe by +10db, then used -10db for all inputs except multichannel which was the same as just boosting the multichannel.) -
Do any Blu ray's output the new formats? If I understand it correctly your reciever does not need to decode the new formats because the BR players can only output multi-channel (like SACD's). Is this right?
I also have the 805 and a PS3, what you are seeing is correct, the 805 reads the lossless audio tracks as "multichannel". Do this, when playing a movie hit the pop-up spec menu on the PS3 for the movie, it will tell you exactly what audio track (TrueHD, DTSMA-HD, DD+...etc) is playing along with a bunch of other tech specs on the movie.If...
Ron loves a film = don't even rent. -
daniel_paul_ wrote: »Do any Blu ray's output the new formats? If I understand it correctly your reciever does not need to decode the new formats because the BR players can only output multi-channel (like SACD's). Is this right?
There are several existing blu-ray players that bitstream TrueHD and DTS-HD MA. Including the latest from Samsung and Panasonic. Expect this to be a more standard feature on blu-ray players going forward. Saying that blu-ray players can only output multi-channel is far too general a comment.
