Here's The Most Craziest Thing That Happens And Need Answers?
joker187
joker187 Posts: 25
so i got a kenwood KAC-9125D it runs at 500wx1@4 ohms 900wx1@2ohms 1800w max. theres a + + - - if i hook both up seperate will the 1800w apply or will it split the power in two?
also i had it hooked up blew the battery fuse, changed the fuse turn car on and it workd. turned off, turn key back now it don't work...HERE'S THE MOST CRAZIEST THING THAT HAPPENS AND NEED ANSWERS?
i put a screwdriver to the gnd screw try to unscrew it and touch the amp with the screwdriver.....light comes on it works when i take it off it doesnt?when i lean the screwdriver on the amp when touching gnd screw on amp it work, when i dont lean it comes off? wtf is goin on, hooked up other amps they work just fine, need a bigger wire i got a 8awg(500w rms) running to it?do i have a short in a wire?is the amp i protect mode. Hooked up to another vehicle works fine?
Post edited by joker187 on
  • sandworms
    sandworms Posts: 1,043
    edited July 2008
    try the car audio forum, they would be more knowledgeable
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
