box help
snappyjb67
hello,
I am getting two DVC GNX 12's and i want to build a box for them. i have seen many iso baric bandpass boxes and would like to build one for these subs. also if there is another box idea you could give me that would be great!
thanks a lot!
thanks a lot!
Post edited by snappyjb67 on
a "V" shape with the box for the two woofers making a V and each woofer firing toward the center on one "leg" of the V. Basically so that they are angled facing each other and out at the same time. This usually leads to a reinforced "thump", something much stronger than if you simply faced them both forward or backward or whatever in a sealed or ported.
I'd do it in a V and vent/port each of them as per their specs (which I could't tell ya off the top o fmy head).Testing
Testing
Testing
