need help finding a truck box to fit my MOMO MM2104............
I have a regular cab Chevy pickup and need a sealed truck box to put my MM2104 in and I'm having trouble finding one the right size. The recommended sealed box volume is .66 cu ft. and the top mount depth is 5.75". Can anyone help me find a box or give me the dimensions the truck box needs to be.
Post edited by bgrass on
You will get better response in the "On the Move" section.
engtazengtaz
