I need help finding a box to fit my MOMO MM2104........
bgrass
bgrass Posts: 4
I have a regular cab Chevy pickup and need a sealed truck box to put my MM2104 in and I'm having trouble finding one the right size. The recommended sealed box volume is .66 cu ft. and the top mount depth is 5.75". Can anyone help me find a box or give me the dimensions the truck box needs to be.
Post edited by bgrass on
  • seeclear
    seeclear Posts: 1,243
    edited June 2008
    Welcome to Club Polk! You may get more/better responses over in the car audio section of the forum. FWIW
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
