LSI-C no Midrange
Tweeter is working but no Midrange is being produced from the 2-5 1/4" Drivers. Any suggestions? Are the midranges blown? I cant recall pushing them hard. I have reversed the wiring and tried it on two different amps.
John
Post edited by John Roberts on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2008
    Make certain your brass jumper straps are in place on the speaker posts.
  • John Roberts
    John Roberts Posts: 2
    edited June 2008
    Hey Tennis,
    Jumpers are screwed down. I pulled out the midrange driver and directly hooked it up and it played. Any other suggestions...do I have a blown crossover?
  • Dennis Gardner
    edited June 2008
    Hey Tennis,
    Check all the connections to the crossover, but it sounds like it could be the issue.
  • McLoki
    McLoki Posts: 5,231
    edited June 2008
    Just to make sure there is a good connection, try to hook your speaker cables to the lower posts rather than the upper ones. (should not make a difference - but if the brass jumper srips are loose, you will get bass with no highs that way)
    Give it a shot and report back.
    Michael
    BTW - welcome to club polk. :)
  • hockeyboy
    hockeyboy Posts: 1,428
    edited June 2008
    Try checking the settings on your AVR. It may have accidentally gotten switched to "Small or Large".
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • mdschlayer
    mdschlayer Posts: 209
    edited July 2008
    Just wanted to comment about my Lsi Center - I never hear anything coming from the left woofer. I wish the crossover was higher to let more low-mids come through. My opinion is the right woofer does alot of work without the help of the left. If this was changed, I could see the mids coming through louder & clearer.
    I am happy with the tweeter and the highs.
    LSi15's, LSiC, LSiF/x's, LSi7's, vr3 crossover upgrades, SVS PC-12 Plus, SVS SB-16 Ultra, Marantz AV8805, Parasound amps, LG OLED65C9PUA, Clarus Crimson, Signal Cable, Atlas Cable, Shunyata and Synergistic A/C conditioning, dedicated Cardas 30A and Furutech 20A AC lines, Box Furniture, Solid Tech ROS, Symposium roller blocks
  • Dennis Gardner
    edited July 2008
    mdschlayer wrote: »
    You are experiencing the cascaded/tiered crossover design built for the LSiC. A number of people have expressed concern over both mid-woofers not putting out the same sound. I think this is mostly by those running the speaker without grills and noticing one driver working harder than its seemingly identical brother on the other side. My experience is that with the grills on, I tend to get the focus back on the music/film at hand and forget the gear.
