PSW303 or PSW10?
I need to get my parents a subwoofer for their home theater. I'm basically trying to spend about $200 on each speaker set ($200 for the center, $200 for the fronts, $200 for the rears, and $200 for the sub), and I'm looking at getting used speakers to get the best bang for the buck. I've come across a couple of subwoofers that I think might do the trick and be in the right price range - the PSW303 and the PSW10. I'm wondering which you guys think would be best for a 12' x 15' room that is open on two sides to other rooms. They will mainly watch movies and TV.
Or do I really need to convince them to shell out the extra $ for a PSW505 or something like that?
Thanks!
Thanks!
2-channel
Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
Post edited by dbaldus on
I had a PSW10 for about a week. It was OK and really shone with some material, but placement was touchy and it tended to fall apart and get sloppy with demanding material.
The 303 is a beast in compact clothing. It's athletic and musical. At the same price it's an easy decision for me.Currently listening to:
Marantz SR5004
Sony BDP-S370
Apple TV V2
Audio Technica AT-LP120
Mirage CMD-5 x 5
Bic H-100 -
Do you really think a 303 is good enough for a medium sized room like the one at my parents' house, or will it be too small? The 8" woofer bothers me...
2-channel
Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2 -
Bigger might be better....
I will say that I'm a satisfied PSW303 owner - which might be a very exclusive minority!
My layout seems to have some positive characteristics that make the PSW303 work for me. And I do like the volume to go up to fill a room.
I'd also consider the listening habits of your parents - unless they are metal heads or are trying to recapture lost youth and want to recreate a Who concert at 120db, the PSW303 might work given your budget
What other speakers are you planning to use - that might also be a factor to consider when matching a sub.
Just stirring the pot....
Erik
Good point about my parent's listening habits.
Well, they are basically leaving it all up to me. I'm planning on purchasing a bunch of the monitor line speakers (unless I find a killer deal on some Rtis). But I was basically thinking Monitor 50s or 40s for the fronts, CS1 or CS2 (if I can find a good deal) for the center, and then either 30s or 40s for rears. Would the 303 be a good match for that setup?
2-channel
Thanks!
Check Amazon they have a FREE deal on the PSW10.
http://www.amazon.com/gp/feature.html/ref=amb_link_5919152_1?ie=UTF8&docId=1000160431&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=hero-quick-promo&pf_rd_r=1XSYT5N12320RXXR1RNZ&pf_rd_t=201&pf_rd_p=409838701&pf_rd_i=B0002KVQBASony KDL-52XBR4
Onkyo Pro PR-SC885P
NAD T975
LSIi15's front
LSIiC center
LSIiFX's surround
LSIi15's rear
PSW1000
Sony BDPS2000ES
2nd system
Sony STRDA5300ES
Sony PS3
LSi9's front
Klipsch sub
under construction -
Not a tough choice...303 all day long.SAMSUNG HL-S42 DLP
harman/kardon AVR225
SONY PS3
polkaudio RTi8's
" CSi3
" RTi6's
Velodyne VRP1000 -
Thanks!Currently listening to:
Marantz SR5004
Sony BDP-S370
Apple TV V2
Mirage CMD-5 x 5
Bic H-100 -
Fry's.com or outpost.com
1 velodyne sub...129.00
http://shop4.frys.com/product/4674948?site=sr:SEARCH:MAIN_RSLT_PG
4 "maple" (parents 'MOM') will love the color 260.00
http://shop4.frys.com/product/5569410
As for the center...don't skimp...mom and dad like to hear and this is where you need to invest...I'd say find a used Csi5 (GOOD FREAKIN LUCK) or find a better deal on a CSI A6. Tweeter, if they are near you may be able to get you a csi3 or 5 for real cheap
http://shop4.frys.com/product/5403309?site=sr:SEARCH:MAIN_RSLT_PG
So in all you should be able to get away with about 550.00 in speakers...I'll tell ya the maple 50;s will make your mom fall in love.Retired Onkyo 520 (returned broken HK 247)
Now a Pioneer 1018
CSi3
2- RTI10's
2- R50's
2- Fxi3's
Onkyo 250W Sub
Polk psw-10
"Inch by inch lifes a cinch, yard by yard life is hard" -
Good idea KChill...that velo vx10 is a steal at that price! For that money, grab two, OP.SAMSUNG HL-S42 DLP
SONY PS3
polkaudio RTi8's
" CSi3
" RTi6's
Velodyne VRP1000 -
The 303 is a much better sub than the VX10.Currently listening to:
Marantz SR5004
Sony BDP-S370
Apple TV V2
Mirage CMD-5 x 5
Bic H-100 -
Don't settle for the Psw10 even if it is thrown in free. It is the bottom of the barrel- don't waste your time.
