6 LSi9 line source...
SlowcarIX
SlowcarIX Posts: 887
edited June 2008 in Speakers
any down side...and if works, whats the best way to power the column of LSi9s?
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Post edited by SlowcarIX on
  • Shicks18
    Shicks18 Posts: 397
    edited June 2008
    haha holy hell, whats your plan this time!
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • hockeyboy
    hockeyboy Posts: 1,428
    edited June 2008
    Power with natural gas or coal.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • amulford
    amulford Posts: 5,020
    edited June 2008
    Your going to have problems with that. Line arrays work with the driver spacing calculated and equal. Your not going to have that, not to mention you don't need all those tweeters.
    You need about 2kW to drive it.
    your also going to have signal delays from the crossovers...
  • dkg999
    dkg999 Posts: 5,647
    edited June 2008
    I would split them into 4 columns of 3 LSi9's and go retro with quadraphonic sound :p
    DKG999
  • Face
    Face Posts: 14,340
    edited June 2008
    What are you trying to achieve by doing this?
  • unc2701
    unc2701 Posts: 3,587
    edited June 2008
    Terrible idea. A line array needs to be designed from the ground up, not just by stacking a bunch of monitors up.
    Amulford hits the major points, but that's just scratching the surface of why its a bad idea.
    Backburner:Krell KAV-300i
  • iskandam
    iskandam Posts: 704
    edited June 2008
    why not just get a pair of AV123 LS6 Line source towers? They've been getting nothing but rave reviews. And if you really wanna take it a step further, wait for its bigger brother LS9
  • Shizelbs
    Shizelbs Posts: 7,433
    edited June 2008
    That will only work if you do it with a seventh pair and one of those $15 T-amps.
  • hoosier21
    hoosier21 Posts: 4,415
    edited June 2008
    I bet it would sound good, why all the nay sayers?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • obieone
    obieone Posts: 5,077
    edited June 2008
    LOL! I was thinking of doing that w/ my 2 60's and 4 30's. Run them in 7 ch. stereo and call them Monitor 120's:eek::D
  • GelatinousFury
    GelatinousFury Posts: 82
    edited June 2008
    Bolt 6 lsi9's together like you have pictured and from henceforth refer to them as LSI54 AURAL DEVASTAT0RZ
  • amulford
    edited June 2008
    hoosier21 wrote: »
    Nah, you'd get all kinds of comb filtering and delayed echo. Your soundstage would be ****, too.
    'course that all depends on what you're tryin to do...
  • SlowcarIX
    edited June 2008
    iskandam wrote: »
    yep...was try to find a cheapER alternative to the LS9 :D
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited June 2008
    lol...LSi54 :D
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited June 2008
    hockeyboy wrote: »
    too polluting...how about this ;)
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited June 2008
    amulford wrote: »
    whats comb filtering anyways? it seems that only polk is dealing it with the cascade taper xovering...?
    my 7.(1x4) HT setup
    Buttkicker
  • maximillian
    maximillian Posts: 2,149
    edited June 2008
    Comb Filtering is constructive and destructive interference from two points of identical sound. It messes with your sound stage and imaging. It occurs with one set of front speakers also because of reflections in a room. This is why people are also into room treatments.
    I tried mixing RTi6's with R50's. They were about 1.5 feet apart of eachother and separated by about 8-10 feet. At first it sounded great. They I realized that imaging was pretty much lacking. I stacked the 6's on the 50's like you have and horizontal imaging greatly improved. However, I still lack height and depth. I would imagine 6 sets of front speakers to have all sorts of problems.
  • SlowcarIX
    edited June 2008
    does comb filtering only happen when theres 2 speakers?
    my setup has a hard time reproducing height, everything else is fine....:confused:
    my 7.(1x4) HT setup
    Buttkicker
