RM6750 and R15
OmegaSupreme
Hi Polk addicts. I sold an RM6750 set and a pair of R15 bookshelf speakers to a friend and was wondering if it might be a good idea for him to make them into a 7.1 channel system by replacing the RM6750 satellites with the R15 to be the front speakers and use the two satellites as rear speakers. Is there any techincal problem with this such as power or voice matching or resistance? I have no idea. Or would it be better to use the R15 as rear speakers? My friend is not particular about these things and is just happy to get all the speakers for $50 and upgrade his sound from tv speakers to 7.1 surround. I just wanted to make the most out of it and figured the bookshelf speakers might have a lower bottom end so they might be better as the fronts for this system. Thank you all. Omega Supreme.
Post edited by OmegaSupreme on
use the bookshelfs as the fronts. I believe all those speakers will run at 8 ohms and are rated up to a 100 watts each. Should be ready to rock out.
