Sub Slope Setting???
xandra
My sub (KEF PSW2500) allows you to set the Slope to 12 or 24db.
the paltry instructs say: 'Slope:Used to adjust transition between speakers and subwoofer."
Can someone tell me what I should set this to for my Polks? and perhaps why?
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
Post edited by xandra on
What are your mains? Frequency response?
Personally, I play around with difference crossover frequencies & slopes until it sounds transparent to me.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
RTi10's are my mains:What are your mains? Frequency response?
freqResp: 20Hz - 27 kHz
-3db Limits: 35H - 26kHzLR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
I'd use 24 dB/octave. It's a steeper roll off, you'll get less lower midbass information that may attract attention to the sub. Most subs in the midbass are really muddy sounding and are better left to the main speakers to reproduce.-Eric
-Polk Audio -
Thanks Eric - that's one variable I can stop playing with.LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
