Tannoy Sensys DC2
Systems
Systems Posts: 14,873
edited June 2008 in Speakers
I'm looking into getting a set of these http://www.tannoy-speakers.com/s.php?product=130&title=Sensys+DC2&s=32 from my local hi-fi shop. Pretty good price too. I was also looking at getting the matching speakers for my HT set-up. But thinking really hard about just the DC2's for a 2 channel system. Your thoughts?
btw....I'll still be employing my SDA's in a 2 channel system.
Chuck
Testing
Testing
Testing
  • Face
    Face Posts: 14,340
    edited June 2008
    They'll work great for HT. As for 2ch, you may need a sub for a larger room.
    I have 4 pairs of Tannoy's here, so you could say I'm a fan.
  • Systems
    edited June 2008
    specs show they dip to 34hz so I'm thinking that may be deep enough. I could be wrong and if I am I have a PSW1000 I could use in a 2 channel set-up. Or I could swing a new sub that is a little faster.
    I also have access to the matching center and rear surrounds if I wanted to use them in HT set-up.
    Chuck
    Testing
    Testing
    Testing
  • Ferres
    Ferres Posts: 310
    edited June 2008
    The DC2's can go deep, well enough for most CDs. Very revealing, clean and focused sound. I've used them without subs.:p
    You'd be hard pressed to find better speakers at their price range.:D
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • Face
    Face Posts: 14,340
    edited June 2008
    I also like how they went back to paper cones. They definitely sound better than the plastic cones that were used for the last 10+ years on the lower models.
  • Systems
    edited June 2008
    The concentric plus the super tweeter really make these babies sing. I auditioned these with my Jolida 801 & a Music Fidelity CDP and it was sweet. I'm torn between getting these and adding the matching center and surrounds for my HT set-up...or just using these in a 2 channel set-up and going with something different in the HT.
    Chuck
    Testing
    Testing
    Testing
  • lakesailor
    lakesailor Posts: 319
    edited June 2008
    I don't think you can ever go wrong with Tannoy. Very nice speakers.
