What to spend more money on: external DAC or pre-amp?
fatchowmein
fatchowmein Posts: 2,637
edited July 2008 in 2 Channel Audio
Alright, so my last thread seeking a comparison between a DAC from an AVR vs an external DAC (Onkyo 805 vs Benchmark DAC1) culminated in an overwhelming support for a quality external DAC. Let me try this from a two channel angle. Let's assume you're running LSi15's with 300W per channel in a medium size room and you're using a budget CD player or Squeezebox with spdiff (let's avoid the optical vs coaxial debate) and no vinyl. How important is the pre-amp when you're using a quality DAC like the Benchmark (DAC1 or higher) if you're budget is $1,500 for a pre-amp and DAC? Do you spend as much of the budget as possible for the DAC or do you need to give serious consideration to the pre-amp for things like bass management and whether the pre-amp will color the output?
Basically, how would you put together a system like this with a $1500 budget assuming you already own the digital player, amp, and speakers?
digital player -> external DAC -> pre-amp (or receiver)
Does anybody have a "giant killer" 2 channel digital playback solution on a budget?
How about a shoestring budget (you define shoestring)?
Post edited by fatchowmein on
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2008
    Maybe get some Musical Fidelity gear. They have great Preamps and DACs.
    Or, they make a preamp, cd player, and DAC all in one. . . Think it's the CD Pre-24. They go for $1000 - $1500 used on Audiogon.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Gaara
    Gaara Posts: 2,415
    edited June 2008
    IMO modded Squeezeboxes sound quite good for the money, especially those that bypass the op-amp. A nice budget DAC would be a MHDT Paradisea, or perhaps a Peter Daniels Audio Sector, both can be had for <$400 and sound phenomenal. Plus if it is a one source rig you can use the SB3 as volume control to, and get a more basic pre for less $.
    As for a pre a few member on here use TVCs and like them. You can get phenomenal sound for ~$300-400 used, hard to beat for the money. If you care about stereophile ratings last I checked they are Class B rated, among a bunch of $1-$2k pres.
  • madmax
    madmax Posts: 12,434
    edited June 2008
    In my opinion you need excellent quality in both. I guess if I had to choose one I would put the money in the preamp. I've always noticed larger changes in the preamp section. It could go either way though.
    Vinyl, the final frontier...
  • joeparaski
    joeparaski Posts: 1,865
    edited June 2008
    I am thoroughly happy with my Emotiva MMC-1 pre/pro and MSB Link Dac III with the Full Nelson upgrade. And it fits within your budget with some money left over to get more SACD's from HK.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • schwarcw
    schwarcw Posts: 7,341
    edited June 2008
    I'd invest in the preamp, then a quality CD player with a good on board DAC. On board DAC's have improved tremendously over the last 5 years. Get a newer MF, Marantz, tube CD player etc. Buy a quality player used and save a ton of cash, same for the preamp. There is a lot of discussion in the threads on this topic.
    Good luck!
    Carl
  • fatchowmein
    edited June 2008
    Nice. Different strategies all around. I guess we're back to that magic word: synergy.
    Thx for the feedbacks.
  • steveinaz
    steveinaz Posts: 19,538
    edited June 2008
    The Benchmark DAC is a preamp for any digital input..I use mine this way. My BluRay is run via Toslink, my CDP via Coax. Viola, done. I had the Musical Fidelity A3CR preamp--I liked the Benchmark better.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2008
    the pre-amp is most important, you only need a dac if your player's dac is lacking.
    player>pre-amp>amp all run analog.
    a great system would be the older NAD gear. well under a grand for all three pieces. no remote use your arm.
    RT1
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    I'll jump on this thread if I may. I have a Sony changer that I won't give up. I have two kids that are small. Keeping the CD's in the changer is so convenient, and safe. I have an Outlaw990 which receives great reviews, but I think the DAC may be lacking. The whole Pre may be lacking for decent two channel. I have been wanting an Adcom DAC for some time now, but I am not sure if I should build a tube buffer first, or think about a different Pre.
    Thanks fatchowmein
    Ben
    Ben
  • AndyGwis
    edited July 2008
    DACs are always a safe option. If you don't like it, usually easier to sell then a preamp, in my opinion. I ran my Sony SCD-C2000ES with it for a while and noticed an improvement. This way, you get great redbook, great SACD, headphone output, all on a very decent budget.
    BTW, I have a Theta Pro Progeny DAC laying around if you want to give it a whirl.
  • organ
    organ Posts: 4,969
    edited July 2008
    Both should be good quality. Having a weak DAC will handicap your pre and having a weak pre will handicap your amps.
    I agree with Gaara on this one. I also find the passive autoformer based pre amps to be VERY good.
