Tubes 6GM8 / ECC86
ben62670
ben62670 Posts: 15,969
edited June 2008 in 2 Channel Audio
What brands are good in these tubes, and are there any brands I should avoid? These things are getting scarce.
Ben
Ben
Post edited by ben62670 on
  • Face
    Face Posts: 14,340
    edited June 2008
    Taken from: https://www.tubeworld.com/6e5.htm
    6GM8=ECC86 Dual Triode
    (the best sounding are Telefunken, Siemens and Amperex Holland)
    Wavelength Cosecant USB DAC
    3 pairs $80/pair) 6GM8=ECC86 Amperex Holland branded as Siemens NOS "O" getter halo in Siemens boxes around 1966 (recommended)
    8 pairs $60/pair) 6GM8 Amperex Holland NOS 1970's A-Frame (sweet sound, quiet pairs)
    2 pairs $60/pair) 6GM8=ECC86 Amperex Holland branded as Siemens NOS in Siemens boxes around 1970 A-Frame (recommended)
    1) 6GM8 Amperex Holland branded as Motorola Germany NOS 1960's $35
  • fredv
    fredv Posts: 923
    edited June 2008
    Hi Ben,
    All the 6GM8 that I have purchased (3 different brands, Westinghouse, GE, and Ampex) have the same A-frame structure that only Ampex used in their 6DJ8/6922 tubes. The Made In Holland label also a strong indication that they were indeed made by Ampex. If I am not mistaken, Ampex was the only manufacturer of this tube. So, don't worry about the brand too much.
    -fredv-
  • ben62670
    edited June 2008
    Thanks guys. I am deep into research now. I feel a Valve-state amp coming on:eek:
    Ben
  • organ
    organ Posts: 4,969
    edited June 2008
    Wow, prices aren't bad at all. That type doesn't seem to be mainstream in equipments yet. If you're planning to use the equipment for a long time, get your NOS supply while it's still easiy available and cheap.
    Fred,
    I think he was looking for ECC86 and you accidentally punched in 6DJ8/ECC88.
    If you have any labeled "Made in Gt. Britain", it's the same tube but made by Mullard on Ampex tooling in later production. I have quite a few of them. The A frame is one of my fav.
  • ben62670
    edited June 2008
    They can still be had for $10 each;)
    I love the low voltage these puppies are very content to live with:)
    Ben
  • organ
    organ Posts: 4,969
    edited June 2008
    Same brands for other types are waaaay more than $10 a piece. You're very lucky. Are you using them in your pre-amp?
  • ben62670
    edited June 2008
    Yes sir. I am shooting for a tube pre/headphone amp. I might even do an active XO with tubes;)
    Second project is going to be a tube line stage to a gain-clone LM3886.
    Third project I want to do will be a tube input stage, and tube voltage amp, and solid state output stage like a GFA-565.
    Ben
    Ben
  • organ
    organ Posts: 4,969
    edited June 2008
    You're gonna be busy for a while. Wow! What speakers are you running? Have you heard low powered SETs? A lot of DIY'ers like to play around with SETs because of the simple circuitry.
  • ben62670
    edited June 2008
    organ wrote: »
    http://www.polkaudio.com/forums/showthread.php?t=53273:o
    No SET's
    I like my transistors like me.
    BiPolar:D
    Ben
  • fredv
    fredv Posts: 923
    edited June 2008
    Hi Maurice
    Long time no see. Yes, I did mean 6DJ8/6922. The 6GM8/ECC86 is essentially a low voltage 6DJ8/6922. No kidding, it sounds very much like the Ampex A-frame to my ears. Look at how much a NOS A-frame costs you, the 6GM8 is really a bargain especially it is a genuine cousin of the A-frame from Ampex!!
    -fredv-
