Which receivers have proper pre-amp output voltage?
jpolz
I'm shopping for a new receiver and since it will be used as a pre/pro for my LPA-1 in my main listening room, I wanted to make sure that the pre-amp out voltage is sufficient as to not distort/compress at higher volumes or destroy the speakers. I'm currently looking at the following units:
Onkyo TX-SR705
Onkyo RX-SR805
Sony STR-DA3300ES
Sony STR-DA4300ES
H/K AVR-354
Does one brand or model have higher output voltage capabilities and what is considered proper voltage? Is there any way to tell or am I going to have to take my VOM with me to the store? It doesn't seem to be a spec that is given by any of the manufacturers.
Onkyo TX-SR705
Onkyo RX-SR805
Sony STR-DA3300ES
Sony STR-DA4300ES
H/K AVR-354
Mains: Polk LSi15
Pre/Pro: Yamaha RX-V663
Amplifier: Emotiva LPA-1
Subwoofer: KLH ASW8-120b
Post edited by jpolz on
Your LPA-1 has a gain of 29db, so a pre w/ 1 volt output should drive it fine. Usually you can find that spec in the manuals- those sony's have 2v outputs.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I had an HK AVR-235 that worked very good. Also the Onkyo 805 is very popular around here. Good deals can be found on both models.
Happy hunting
Ben -
I had a good experience with using HK as a pre/pro also."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
