Club Polk forums Mobile version
MKZ
When will it happen?
I just cant stop keep browsing like while Im on boring meeting or waiting for my wife shopping, etc
Post edited by MKZ on
Depending on your phone, just download Opera Mini.
Make sure to turn off images, and you're good to go. It has a very intuitive zoom interface that makes browsing non-mobile pages pretty painless. It renders everything so it's readable on your phone. Just a very smart, good setup.
Ideally there'd be a mobile version but until then it's a great browser. And free, so worth a try at least.If you will it, dude, it is no dream. -
I browse all the time using Opera Mini and it works great on my Blackberry Curve...
Thanks. I'll try that.
Does it take over as default browser? Or there will be an option? -
I use Opera Mini as well on my Blackberry.......great software. Porno on my blackberry is a bit small, but it works.
Depends on your phone I guess; for mine I have to launch it as a separate app, as my phone has no concept of a "default browser" other than its own built-in one.If you will it, dude, it is no dream. -
****, I don't see my phone as being supported. I have the new Moto Q. The old Q is listed. Think it will still work?
It installed as separate application and works great. Thank you.
There is generic version. Or you could browse with your phone and they will suggests one. -
Yep. -
Yeah, it works with nearly every phone that supports Java. At the very least it can't hurt to try - it's free and you can always uninstall.If you will it, dude, it is no dream. -
Cool, thanks. I've been wondering the same sort of thing about there being a mobile version in the works. Can't download straight from my phone. I'll have to wait until I get home.
Just downloaded opera mini and I'm posting on it now. Much better than using the default browser.
