PS3 and Harmony Remote
edossin4
edossin4 Posts: 105
edited June 2008 in Video Games
Okay people I need some help. I understand the PS3 is bluetooth and will not work with the IR Harmony 880 remote. I got a Nyko Blue Wave IR remote and I am having a hard time setting this up with the Harmony.
Will this remote turn on the PS3? Where on the harmony website do I go to set this up right:confused: Or in other words how do I program this Nyko into the harmony?
Onkyo Tx sr805
Oppo Dv-981hd
Onkyo Dv cp704
Adcom Gfa 555
Adcom Gfa 545
Polk Audio rti 12
Polk Audio cs400i
Polk Audio fx300i
Panasonic 54" rear projection
Direct HDTV DVR
PS3
Post edited by edossin4 on
  • phuz
    phuz Posts: 2,372
    edited June 2008
    I have the same issue.
    As I understand it, nothing else will turn on/off the PS3 other than the bluetooth remote or game controller. You have to get up to put the disk in anyway, so might as well turn it on/off then.
    I think you may have to teach the harmony the Nyko codes, as the Nyko is probably a generic or not registered type of system.
    I'd be curious to know as well. I could figure it out, but I just haven't had the time.
  • edossin4
    edossin4 Posts: 105
    edited June 2008
    Sure you could:rolleyes: If you have time to answer this post you have time to work on a solution to our problems.
    Just jokes!:p
    Onkyo Tx sr805
    Oppo Dv-981hd
    Onkyo Dv cp704
    Adcom Gfa 555
    Adcom Gfa 545
    Polk Audio rti 12
    Polk Audio cs400i
    Polk Audio fx300i
    Direct HDTV DVR
    PS3
  • BeRad
    BeRad Posts: 745
    edited June 2008
    **** thing:
    You CAN NOT nor will you EVER be able to turn the ps3 on and off using the ir remotes that have the usb dongle. The wiring just isn't there internally on the ps3 to make it possible. There currently is only one good option for ps3 with universal and that is this:
    (no affil.)
    http://ir2bt.com/cart/
    Keep watching as they are still being manufactured one at a time by hand. I checked every day till I was able to get in on a pre-order and I now have one. Have yet to try it out, but all the codes are already online for it to work with harmony. The nice thing about this gizmo is that it will transfer all your codes from IR to BT and it is meant for the ps3. This means that the ps3 will "think" that the controller is sending the codes to turn it on, off, etc.
    I think i remember finding the info for the nyko dongles somewhere in the forums on the harmony website. Do some digging and I'm sure it will come up in there somewhere.
  • ESavinon
    ESavinon Posts: 3,067
    edited June 2008
    I just set up my mx-700 remote to this: http://ir2bt.com/cart/.
    It works as advertised.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • BeRad
    BeRad Posts: 745
    edited June 2008
    You don' read other posts do you? :P j/k :)
  • Ron-P
    Ron-P Posts: 8,520
    edited June 2008
    Once your remote is plugged in and you're on Harmony's site go to "Devices" and select "Add Device". Go to the drop down menu and select "Game Console (with DVD)" then select "Nyko" under the manufacture option. Enter the model # and update your Harmony. The only thing you cannot do is turn the PS3 on/off.
    If...
    Ron loves a film = don't even rent.
  • Shannon W.
    Shannon W. Posts: 568
    edited June 2008
    This is what you need to be able to use your Harmony with the PS3 and they have a adapter that allows you to turn it on and off. From what I have read on the AV forums it works very well. Hope this like helps you out. http://www.schmartstuff.com/
    Shannon
    50" Samsung Plasma
    Sony STR-DA4ES "use as Pre/amp"
    Pioneer Elite DV-45A DVD Player
    DLO HomeDock Deluxe iPod docking station
    Directv HR20 Sat. Receiver in black
    Sunfire Cinema Grand 7 Signature Amp
    Monster Cable AVS2000
    Monster Cable HTPS 5100 MKII
    Polk LSi 9's Front R/L
    Polk LSiC Center
    Polk LSiFX R/L Surround
    Polk LSi 7's Rear R/L
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
    Click Here To View my Rig
  • shawn474
    shawn474 Posts: 3,052
    edited June 2008
    I still can't figure out how to turn off the PS3 with the blu-ray remote, much less worry about programming my Harmony to control it. How do you turn off the power with the blu-ray remote? I always walk up to the unit and power it off with the button on the console.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • edossin4
    edossin4 Posts: 105
    edited June 2008
    To turn of the PS3 push the 'Playstation' button on the game controller or the remote, it will bring up a menu on screen. From there you can chose 'system off'.
    Onkyo Tx sr805
    Oppo Dv-981hd
    Onkyo Dv cp704
    Adcom Gfa 555
    Adcom Gfa 545
    Polk Audio rti 12
    Polk Audio cs400i
    Polk Audio fx300i
    Direct HDTV DVR
    PS3
  • shawn474
    edited June 2008
    Thanks. That makes it a bit easier.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2008
    It's off topic but does anyone know how long the 2.36 update takes after you say ok to the install? I've had a blank screen for 30 minutes so far.
  • BeRad
    BeRad Posts: 745
    edited June 2008
    That seems a little long. Most other updates were 10 minutes start to finish. I haven't done the 2.36 as I decided to wait for the 2.4 coming up.
    Hopefully you won't have to do a full reset and end up back at square one.
  • dorokusai
    edited June 2008
    I think I'm going to reset.
  • hypertrophy
    hypertrophy Posts: 10
    edited June 2008
    The non compatibility with a universal IR remote is a key factor in my decision to hold off of the PS3 for now. My brother in-law has a PS3, along with a Harmony remote, and the Nyko IR dongle remote, and there is no way to power On or Off the PS3 without using the PS3 controller, or manually pressing the power button on the game console itself.
    The PS3 wants to be an all around media console, yet the lack of an IR receiver port has lead to the inability to fully integrate it into people's home system.
    Center: Csi5
    Fronts: Rti6
    Rears: Rti4
  • BIZILL
    BIZILL Posts: 5,432
    edited June 2008
    BeRad wrote: »
    **** thing:
    (no affil.)
    my ir2bt works flawlessly. my harmony 659 switches many different pieces of gear and turns on/OFF the ps3 without me breaking a sweat.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Frank840
    Frank840 Posts: 262
    edited June 2008
    so how come you didnt buy the harmony ir thingy over the nkyo
    - This your Bush?
    Pioneer Elite Sc-25
    Polk Lsic,15's,9's, PSW1000
