luxman r-351
needaremote
needaremote Posts: 1
edited June 2008 in Electronics
hi,
i own a luxman r-351 stereo receiver. does anyone know where i could get a remote control for it, second hand is fine too? will a universal one work? if so, is it very hard to hook up? (I'm really getting sick of getting up off the couch to adjust the volume :cool:)! thankyou.
  • Airplay355
    Airplay355 Posts: 4,298
    edited June 2008
    If you have the old remote you could probably get a learning remote that will learn the codes from the old remote. If you don't have the old remote you might be able to find a remote at Goodwill or something like that. You wouldn't even have to buy it, just take a learning remote with you and some batteries so you could get the remote codes.
