sony sa-wm40 sub to go along with my setup....
hdoggie24
hdoggie24 Posts: 40
edited June 2008 in Speakers
I have a slightly older Sony sa-wm40 12" active sub and want to know how this would sound with my rm10 set going up soon. I had this sub on an older system I had and sounded great to me. Do you think this sub will be adequate to my system or should I look for something else. Any info?
Post edited by hdoggie24 on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2008
    The Sony subs were some of the best bang-for-the-buck subs on the market 5-6 years ago. There was alot of tweak talk about them on HT Forum and AVS.
  • zingo
    zingo Posts: 11,258
    edited June 2008
    If you think it sounds fine. I would use it. I had one for a while and never had any problems with it; just don't cross it too high so it drowns out the speakers.
  • ohskigod
    ohskigod Posts: 6,505
    edited June 2008
    thats a decent sub, especially if you throw some polyfill in it (pop off the driver, place in the fill, put driver back on. if your really in the mood to tweak, coat the paper part of the driver cone in decoupage glue (I believe the stuff is called mod podge, any self respecting craft store should have it) I did the mods, and the sub still serves in a friend of mine's theater.
    the mods, when I did them, made a SIGNIFICANT difference in making the bass tighter (less flabby)
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
