XLR vs. RCA difference and benefits?
garnier
garnier Posts: 116
edited February 2011 in Speakers
How important is it to have XLR pre-amp outputs instead of RCA outputs in sound qulalities? Would it make a difference when the length is 6 ft long and about 1 ft away from a major AC power cord? :confused:
Post edited by garnier on
  • obieone
    obieone Posts: 5,077
    edited June 2008
    From what I could gleam from this thread(below) it isn't that noticable, unless you're going into GA-GA land $$$
    http://www.polkaudio.com/forums/showthread.php?t=68299&highlight=Balanced
  • ward91
    ward91 Posts: 338
    edited June 2008
    the only real + i can think of for that dist is that a propper ground may eliminate any ground hum ect.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • zingo
    zingo Posts: 11,258
    edited June 2008
    A balanced connection can help with eliminating or reducing hum and line noise. I wouldn't buy for that feature, but if the component I was looking has them, I would use the XLR connections.
  • steveinaz
    steveinaz Posts: 19,546
    edited June 2008
    Ed Zachry. If got it--use it, but don't break the bank buying into it.
  • garnier
    garnier Posts: 116
    edited June 2008
    I see. Thank you for your comments and the link.
    Can I use XLR's for 7 channels, and an RCA pre-amp out just for the subwoofer, because I do not have an XLR input for my sub? In this case, it would be a mixure of mostly XLR pre-amp outs and one RCA pre-amp out from the back of a pre-amplifier/processor? Thank you! :)
  • zingo
    zingo Posts: 11,258
    edited June 2008
    That'll work fine.
  • Monster Jam
    Monster Jam Posts: 919
    Reported.
    My first reported post. Guess I am moving up in the Polk Forum world.
    Do you hear that buzzing noise? :confused:
  • ben62670
    ben62670 Posts: 15,969
    I think you turned evil with your 666th post:eek:
    Ben
  • lakesailor
    lakesailor Posts: 319
    If it is a truly balanced amplifier then there will likely be a 6dB difference in the signal level between the XLR and single ended (RCA) connection standards. Some manufacturers adjust the gain difference to compensate for this difference and others either do not, or do not do a very effective job at it. As a result you often hear a “difference” between running balanced and single ended cabling that is more related to the differences in the gain then anything else.
    Also be aware that sometimes you can get more connection loading with an XLR cable that can cause a spike in your pre-amp, although that is more common working with commercial amps. Odds are with a 6’ run you will be just fine with single ended (RCA) connectors.
    Toolfan66 Posts: 18,161
    I love my XLR's. Cleaned up the sound and a little gain, the only the only thing is mine were expensive using MIT's but glad I have them and paid for!!!
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    Hey, there's some benefit to the spam incursion after all... it's resurrecting three year old threads for us to debate and discuss! Ahhh, spam. :biggrin:
