RTi10 vs. RTi12
edited June 2008 in Speakers
Searched for this on the forum and never found the answers I am really looking for.
My questions are:
1) What would be the better speaker for HT use? I plan on using a subwoofer either way.
2) What is the main difference/advantage the RTi12's have?
3) I have seen that a more people here have the RTi10, why is that?
I think that is all I got for now. Thanks for your help!
TV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3
Post edited by Shicks18 on
Welcome!
    edited June 2008
    2) 12's just got alot higher but need alot of power, cost 2-400 more.
    1) Toss up, both are good
    3) Were easier to find back earlier this year for cheap, got mine for 400 bucks, saved 5-600 easy. And most people found that the 12's are intimidating. I would take them now but the 10's shake my room and blast loud so I'm good.
    Sorry out of order.
    Retired Onkyo 520 (returned broken HK 247)
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
    "Inch by inch lifes a cinch, yard by yard life is hard"
    edited June 2008
    1) Technically, the 12's would be better for HT...
    2) ...becasue they have more drivers, (particually the 7" woofer) and can handle more power...
    3) ...which makes them more expensive, and thus more popular.
    Either are great for HT.What size room? What other peakers would you be using? How will you be powering the speakers?
    edited June 2008
    Both will do an exceptional job for HT applications. Best way to decide this is to listen to both and make your decision based on which one sounds best to you.
    I listened to all 3 Rti floorstanders and found the 8's to sound too thin and the 12 to bassy. The 10's sounded perfect for my ears. You can't go wrong with either of the three.
Welcome!
Welcome!
