Polk SDA-SRS Bi-Amping
daddy6
daddy6 Posts: 7
edited June 2008 in Vintage Speakers
I was wondering if it o.k. to use mono block tube amps with the SDA-SRS speakers.
I was also curious if you can bi-amp two Hafler DH-500 amps to these speakers. Any opinion would be most helpful. Thanks.
Post edited by daddy6 on
  • danger boy
    danger boy Posts: 15,722
    edited June 2008
    don't use mono block amps with SDA's till you find out if it's ok.. usually it's not.. mono block amps are usually not recommended. don't ask me why. i don't know. but someone else in here does.
    PolkFest 2012, who's going>?
    F1nut Posts: 51,899
    edited June 2008
    If your serial numbers are 5001 or greater on both speakers and you have an AI-1 interconnect cable, then the answer is yes. Another possible option is to check with the maker of the tube amps to see if the negative outputs can be tied together.
  • zingo
    zingo Posts: 11,258
    edited June 2008
    daddy6 wrote: »
    You mean like Silver 7s? :D
  • Boywonder
    Boywonder Posts: 225
    edited June 2008
    Plug both monoblocks into the same 110v receptacle, and check (with an ohm meter) for continuity between the negative speaker terminals. If you have continuity (roughly 0 ohms), the amps are common ground and the negative terminals are tied to chassis ground, in which case you should be good to go, no need for AI-1 interconnect.
    If you do not get continuity, check with the amp mfr to see if you can tie the speaker neg terminals together without letting the smoke out of the amps.:D
  • zingo
    zingo Posts: 11,258
    edited June 2008
    Thats a great, easy to understand description Boywonder. I couldn't have said it better myself.
