Polk SDA_SRS Bi-Amp
daddy6
I was wondering if it is o.k. to use mono block tube amps with these SDA-SRS speakers.
I also was curious if you can bi amp with two Hafler DH-500 amps. Any opinions would be helpful. Thanks.
Post edited by daddy6 on
Not unless you can tie the grounds together (check with the amp maker). You will either blow the amp or speakers or both. SDA's need common ground amps. There is a SDA cable you can get to use non common ground amps. Just search for it on the forum.
engtazengtaz
