Quick wiring opinion . . .
SolidSqual
SolidSqual Posts: 5,218
edited June 2008 in 2 Channel Audio
I have a Raysonic CD128 and a Dodd Preamp. With the addition of my Dodd I need to rewire my system with some new Signal cable. In your professional opinion, would it be better to go RCA to RCA or XLR to RCA? Bear in mind, the rest of my system uses balanced cabling as necessitated by my Behringer XO.
Mike
Post edited by SolidSqual on
  • Face
    Face Posts: 14,340
    edited June 2008
    LOL @ the results.
  • SolidSqual
    edited June 2008
    Does anyone believe the Raysonic might have better output through the balanced connections even though the system won't be actually balanced?
    F1nut Posts: 50,734
    edited June 2008
    Unless the components run a true balanced circuit, using XLR's offers no real benefit. Therefore, the correct answer is number one. Don't believe me? Talk to the guys at BAT.
  • SolidSqual
    edited June 2008
    Does F1Nut's opinion trump everyone else's?
  • SolidSqual
    edited June 2008
    Zero wrote: »
    You need beaten.
    God you are no effing help. This is serious bizzness.
  • zingo
    zingo Posts: 11,258
    edited June 2008
    If the XLRs aren't that much of a price difference, it couldn't hurt. You MAY not gain anything, but you won't lose anything either.
