Sub Eq's
jakelm
jakelm Posts: 4,081
Alittle advice needed.
Something inexpensive, that can go between the pre and the plate amp. 1 channel, eq w/ a range from ~18hz too ~100hz. Just something to smoothen out a Fr range.
I have a +5db spike between 30 and 40hz. And a dip between 70 and 80hz. Was hoping a cheap little eq will help. Maybe something less than $100, if possible.
Any ideas?
Jake
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
  • engtaz
    engtaz Posts: 7,669
    edited June 2008
    I suggest checking Craigslist or ebay.
    engtaz
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    engtaz wrote: »
    engtaz
    Thanks buddy, know of anything new? What am I to look for?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Face
    Face Posts: 14,340
    edited June 2008
    Not sure if this has enough features, but it's what you're going to get for $100.
    http://www.edesignaudio.com/product_info.php?cPath=2_123&products_id=657
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    Face wrote: »
    Actually, yes, Face.
    I can dial in on the Fr and cut what I need. From what I'm looking at.
    If I were to go used?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    The Velodyne looks great, but I dont need OSD and all that other rigamaroo...
    A set it and forget is Eq would be nice..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • tryrrthg
    tryrrthg Posts: 1,896
    edited June 2008
    I know you're using room EQ wizard so why not get the Behringer Feedback destroyer that the Room EQ wizard was designed around? I use one and it is great!
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    tryrrthg wrote: »
    Duuuhhhh.... Sometimes I dont think....
    Thanks Try
    Is it really that easy to use. You can cut and raise Fr points?
    http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=248-656
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • tryrrthg
    edited June 2008
    yep, cut and boost. It's not the most intuitive thing to use, but the hardest part about using them was figured out what setting to put into them. Room EQ wizard takes the guess work out of that, it tells you exactly what to put in.
    One thing you want to keep in mind is if you are going to boost anything you're going to need a lot of power and plate amps aren't all that great for that. I would try cutting values around the dip before I would boost a ton...
    edit: this page has a bunch of info about the BFD and R EQ W. It's been a while since I've looked at it, so hopefully it is still relevent...
    http://home.comcast.net/~thomasw-2/SubwooferSetupandEQpage.html
  • bsoko2
    bsoko2 Posts: 1,449
    edited June 2008
    The Anti Mode 8033 is fully automatic and there is no learning curve. It gets it right the first time. With the BDF, Good Luck!
    Bill
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    tryrrthg wrote: »
    Thanks Try,
    And I myself am not a big fan of boosting, generally boost = distortion.
    I am a memeber of Thehometheatershack.com. So I guess I'll get my reading on.
    I am very familiar with REW, so I know that it gives you very good adjustment calculations.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    bsoko2 wrote: »
    Bill
    I understand Bill, however, I am not a big fan of automatic. But having experience with REW, I think the BDF, would be my best choice. $99 a PE isnt a bed deal anyway.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • tryrrthg
    edited June 2008
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Eric W
    Eric W Posts: 556
    edited June 2008
    Velodyne SMS-1 is an excellent subwoofer EQ, though a little beyond your price range.
    -Eric
    -Polk Audio
  • bsoko2
    bsoko2 Posts: 1,449
    edited June 2008
    jakelm wrote: »
    Well it all gets down to how much time you want to spend configuring your EQ? Time is also money and I know the WAF comes into play anytime we play with our toys trying to configure the latest and greatest. The Anti Mode 8033is plug it in, set the mike, push the buttons, and it does it's thing. Try this thread: http://www.avsforum.com/avs-vb/showthread.php?t=1028464.
    Bill
  • Gaara
    Gaara Posts: 2,415
    edited June 2008
    bsoko2 wrote: »
    Bill
    Honestly, do you work for them or something? Every post I have read of yours seems to be pushing this product, even when people say it won't work for their needs.
    This product looks nice for someone who just wants to set it and forget it, with sub-optimal results. The OP can do more with the BFD for within the his price range, end of story.
    treitz3 Posts: 20,121
    edited June 2008
    Eric Wong wrote: »
    Velodyne SMS-1 is an excellent subwoofer EQ.......
    Yes sir it is. ;)
  • bsoko2
    bsoko2 Posts: 1,449
    edited June 2008
    Gaara wrote: »
    To each his own.
  • jakelm
    jakelm Posts: 4,081
    edited June 2008
    I have decided on the BDF.
    Thanks guys...
    Just a few pics of REW, to show you what I am working with. Tmpest X in sealed enclosure, 6.5ft^3
    First pic is 1/6 oct...2nd pic is 1/2 oct
    As you can see the Fr is all over the map.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Ern Dog
    Ern Dog Posts: 2,237
    edited June 2008
    It would be cool to see the graphs after adding the BFD into the mix so we can see the difference it makes. Please post.
