80G PS3, who got one today
edossin4
Who got their 80G PS3 with Metal Gear Solid 4 today?
I was at Best Buy early this morning. I was a little worried because I stopped by Gamestop for the 12am release and there was a line of 50 people for 2 MSG4 Bundles.
Just a few people at BB this morning. They had about 25 units so I had no problems.
Can't wait to hook it up.:D
Onkyo Tx sr805
Oppo Dv-981hd
Onkyo Dv cp704
Adcom Gfa 555
Adcom Gfa 545
Polk Audio rti 12
Polk Audio cs400i
Polk Audio fx300i
Panasonic 54" rear projection
Direct HDTV DVR
PS3
Oppo Dv-981hd
Onkyo Dv cp704
Adcom Gfa 555
Adcom Gfa 545
Polk Audio rti 12
Polk Audio cs400i
Polk Audio fx300i
Direct HDTV DVR
PS3
Post edited by edossin4 on
Some saying Walmart has it with $100 WM gift cards.
http://forums.anandtech.com/messageview.aspx?catid=40&threadid=2196661 -
I picked up the 40 gig version 2 weeks ago. Probably should have waited, but oh well. Does your 80 gig version bundle the new dual shock stick as well?
Although out of stock online, walmart's site specs the bundle as:
$499
PlayStation 3 80GB Limited Edition Metal Gear Solid 4 Pack Includes:
PlayStation 3 80GB
Metal Gear Solid 4 game
DUALSHOCK 3 Controller
Voucher for free downloadable PAIN game
So it's a great deal for those that score it with the $100 gift card with the new dual shock and the games. -
Went to the local best buy at 12am..They had like 30ish units i guess.they gave some numbered coupons...I was the 14th person.No problem..Have to hook it up ..lol
My Walmarts were sold out. Damn...
I was waiting for the 80GB, but I got a 40GB instead after a local Bestuy matched a local Walmart deal (if in stock) for $100 gift card.... hey.. $300.00 for a PS3/40G..
Just saw it has an optical output. That's awesome. I'm looking at the 80GB right now.
Two questions: Does it play SACD (and is it only through HDMI, or are there analog outs somewhere), and will it play PS2 games (I have a bunch somewhere).
Thanks!Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
PS3 has optical out.
Thanks!
80GB does do SACD. I think the only analog outs it has are the stereo analog jacks for backwards compatibility with older TVs. And it does do ps2 games with software emulation. So unless you have an obscure title that they wouldn't release an update for, it should work with thousands of your favorite games. -
So, even without an HDMI receiver, I can get SACD stereo sound from the analog outputs, right?
Thanks for the help/info.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Yes, but you will be at the mercy of the cheap ICs that come with the machine unless you upgrade. The ps3 uses a proprietary connector at the console end. It is the same one the ps2 uses. So any of the 3rd party ICs from Monster, etc. will work designed specifically for use with one of these systems.
Supposedly, the optical also works for listening to 2-channel. And they temporarily had a downsampling method for listening to a multichannel DTS version over optical but it was disabled in a later firmware update.
Your only option for listening to SACD decoded to multichannel high-resolution PCM (24-bit, 176 kHz) remains HDMI, though.
Here's a pretty detailed rundown of your SACD options with the ps3:
http://www.ps3sacd.com/faq.html
