Question about SDA Signature Edition
djronc
djronc Posts: 8
edited June 2008 in Vintage Speakers
I have them hooked up, interconnect cable plugged in, but seems like I have no bass coming from the right speaker. When I pan full left I hear that speaker plus some audio from the right speaker. When I pan full right I don't have any bass seems like just mids and highs. I also get sound from the left speaker. The fuses look good, I think the driver may be shot. Which of the speakers carrry the mid-bass or bass frequencies? I didn't want to open up the cabinet but I hear the potential of how they sound. Someone said they sound good, but knowing that the bass is not right annoys me. Any help would be appreciated. If I have to replace a driver anybody have any suggestions. Also I have read on this site that replacing the tweeters is a recommended upgrade, where do you buy thoses and what are you looking when you buy them.
Thanks in advance,
Ron Carter
Post edited by djronc on
  • dcmeigs
    dcmeigs Posts: 708
    edited June 2008
    Check for a frozen driver(s). They are often damaged during transport by dropping the cabinets.
    New drivers are available from polk at $48 if you mention you are a polk forum member.
    The world is full of answers, some are right and some are wrong. - Neil Young
  • zingo
    zingo Posts: 11,258
    edited June 2008
    I would personally pull the drivers one-by-one and check to see if they work. That way you will know for sure what works. I would also double check your placement of the speakers. They are supposed to be near the wall, but away from side walls. What model do you have?
  • djronc
    djronc Posts: 8
    edited June 2008
    Thanks for the response guys. The model I have are the SDA Signature Edition. From what I understand they were a transition model of the SDA 1.
  • zingo
    zingo Posts: 11,258
    edited June 2008
    Can you post a picture? We will be able to help you best if we for sure know what model you have.
  • engtaz
    engtaz Posts: 7,669
    edited June 2008
    Usually is you get not base it is a aie leak or bad driver. If you push gentle on each driver it should move easily and without a scratch feel. The passive woofer should move.
    Good Luck and welcome,
    engtaz
    engtaz
  • danger boy
    danger boy Posts: 15,722
    edited June 2008
    when you pan left and right on the SDA's this is normal to get sound from the other speaker. at least the three pairs that i've owned did this.
    if you're not getting any bass from one of them.. that means most likely one or more of your mid bass 6.5" drivers is bad. they are what provide your speakers with the air pressure that moves the passive radiator to produce bass.
    as mentioned above. take one out at a time and hook the leads up to some speaker wire and play some music at low levels and see if it produces sound.
    PolkFest 2012, who's going>?
  • djronc
    djronc Posts: 8
    edited June 2008
    This picture was from another post but this is the model speakers that I have. I don't have any other pics right now.
    F1nut Posts: 51,997
    edited June 2008
    Take out the right side PR and check if the front section has separated from the back.
  • djronc
    djronc Posts: 8
    edited June 2008
    Will do, thanks. I will make this part of my week end project. I am putting together a system that includes just old school speakers. My SDA's, Ohm Walsh 100's and a pair of Dahlquist DQ-10's. Just want to see how the different applications sound side by side with the same material. I hope I can get the SDA's operating correctly.
  • zingo
    zingo Posts: 11,258
    edited June 2008
    Ooo, I like that little comparison. Have fun with it!
  • schwarcw
    schwarcw Posts: 7,358
    edited June 2008
    Are those SL1000 tweeters?
    Carl
  • Face
    Face Posts: 14,340
    edited June 2008
    Yes.
  • ben62670
    ben62670 Posts: 15,969
    edited June 2008
    Well I learned something new. I didn't realize any SDA's had SL1000's.
    Ben
