Sub-woofer from RM6800 system
Jazzycrow
I have the RM6800 speaker system and the line in ports on the back of the sub-woofer is loose and causing a lot of feedback. Is this something that's worth sending in for repair or just replace the sub, if repair is the best option does anyone have recommendations for a replacement sub.
Post edited by Jazzycrow on
I purchased it from Circuity City about a year ago as a open box return.
You don't have to send the entire sub in- just the circuit board. Unplug the unit from the wall and the signal connections. Take a #2 Phillips head screw driver, unscrew the screws lining the perimeter of the back panel. You may have to pry a little but the back panel will come off. Then disconnect the red/black wire at the back of the woofer (friction fit).
Send the piece you just removed to our factory service center along with a copy of your receipt & description of problem:
Polk Audio
2550 Britannia Blvd
Suite A
San Diego CA 92154-Eric
-Polk Audio -
Thanks for the information Eric I will have to go back to Circuit City to get the receipt, what if I'm unable to get it.
They should be able to re-print you up a receipt. We need a copy of the receipt for any warranty claims.-Eric
-Polk Audio
