Best setup for LSI 7.1 system
BLACKHAMMERJAMM
What would sound the best.
I have a Kipsch sub12, but will upgrade soon.
I now have LSi 15 fronts LSi C - LSi FX surrounds - LSi 9 rears and a Sony STRDA5300ES. I will also get a power amp to push these speakers. All but the LSi 9's are still in the box, and I may get another set of LSi15's if recommended for a 7.1 system. Please help a noob make the best choice.:)
- LSi 15 fronts LSi C - LSi FX surrounds - LSi 9 rears
- LSi 15 fronts LSi C - LSi FX surrounds - LSi 15 rears
- LSi 15 fronts LSi C - LSi 9 surrounds - LSi 15 rears
Sony KDL-52XBR4
Onkyo Pro PR-SC885P
NAD T975
LSIi15's front
LSIiC center
LSIiFX's surround
LSIi15's rear
PSW1000
Sony BDPS2000ES
2nd system
Sony STRDA5300ES
Sony PS3
LSi9's front
Klipsch sub
under construction
Onkyo Pro PR-SC885P
NAD T975
LSIi15's front
LSIiC center
LSIiFX's surround
LSIi15's rear
PSW1000
Sony BDPS2000ES
2nd system
Sony STRDA5300ES
Sony PS3
LSi9's front
Klipsch sub
under construction
Post edited by BLACKHAMMERJAMM on
What size is the room, I wouldn't recommend 7.1 unless you have a large room.
As for 15's as rears, why not? My rears have 2 8" woofers each, it's nice to be surrounded in bass."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
30'X26' Is this large enough for 7.1?Sony KDL-52XBR4
Onkyo Pro PR-SC885P
NAD T975
LSIi15's front
LSIiC center
LSIiFX's surround
LSIi15's rear
PSW1000
Sony BDPS2000ES
2nd system
Sony STRDA5300ES
Sony PS3
LSi9's front
Klipsch sub
under construction -
Shweet. Are you refinishing the room? What kind of room is it? Layout?
Lol it's just a living room, and has never been finished...New house from 2004 that I'm still painting...Sony KDL-52XBR4
Onkyo Pro PR-SC885P
NAD T975
LSIi15's front
LSIiC center
LSIiFX's surround
LSIi15's rear
PSW1000
Sony BDPS2000ES
2nd system
Sony STRDA5300ES
Sony PS3
LSi9's front
Klipsch sub
I say go with the 15's and FX's. Keep them all on the same elevation, too. Your gonna need a couple of good subs, too. And POWER, don't forget the power...
For LSiFX, mount them two or more feet above the ear level (according to THX website for setting up 7.1 mode), and put them in dipole mode. You don't want to know where the sound is coming from, for the side surround speakers!
I have a 7.1 setup now, and noticed that the rear surround speakers are not used as often and as much as the front or center speakers. I would go with LSi9 for the rear surround speakers, and instead add a second subwoofer to be placed in one of the rear corners in the living room. -
Why not drop the 9's and use FX's for all of the surrounds? That's how I would probably roll it.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
