Small nut inside of speaker
paymontna
paymontna Posts: 188
edited June 2008 in Speakers
A nut slipped out of my hand and fell between the baffle of my Lsi 9 and I think it was sucked into the bass port. What to do? :eek:
And I mean calling all cars, blackhawk down, mushroom cloud, Three Mile Island, lock the door behind you kind of mad.:mad:
Post edited by paymontna on
  • Face
    Face Posts: 14,340
    edited June 2008
    Hold it upside down and do the chicken dance.
  • paymontna
    edited June 2008
    Face wrote: »
    I did more than the chicken dance. All I could think about was...."We are caught in the tractor Beam."...."Use the Force Luke". I shook it every which way w/o getting crazy.
    Pay
  • TNRabbit
    TNRabbit Posts: 2,168
    edited June 2008
    It's stuck to the speaker magnet now.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • paymontna
    edited June 2008
    I have another magnet that I could use to try and fish it out with, but I do not want to screw up the polarity of the speaker magnets. Is that possible. OR, I could crank up my pb plus 2 and blow it out.
  • dane_peterson
    dane_peterson Posts: 1,903
    edited June 2008
    Hilarious.
    Edit: Oh, like a bolt NUT. I thought you meant a pistachio or something. Not as funny now.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2008
    I have nuts (foam peanuts) stuck inside the LsiC I just picked up. Thanks for the awesome packaging job, dude that sold it to me!
    Took off a driver and the crossover to fish most of them out. . . but I can still hear one or two of them in there if I shake it.
    Drivers are easy to remove with a screwdriver, just don't poke any holes while you're **** / unscrewing. You should fine the nut against one of the magnets inside.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • dorokusai
    dorokusai Posts: 25,577
    edited June 2008
    Hilarious.
    That's what I was thinking as well....I was like chew with your mouth closed for gosh sakes. Funny stuff.
  • RutgersFTW
    RutgersFTW Posts: 458
    edited June 2008
    I had the red binding post tightener slide out of my hand while removing the jumpers off a pair of RTi8s and it hit the Power Port just right to slide inside. Luckily, the Power Port unscrewed easily and a few minutes shaking worked it out. That was plastic, though. Good luck with your problem.
    Currently listening to:
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Audio Technica AT-LP120
    Mirage CMD-5 x 5
    Bic H-100
  • paymontna
    edited June 2008
    Anybody have sound advice (no pun intended) on how to get it out. The baffle on the back does not have any visible means of removing it. I do not want to trash my speakers.
    Pay
  • dorokusai
    edited June 2008
    Remove the drivers.
  • amulford
    amulford Posts: 5,020
    edited June 2008
    What he said. They might have some sort of sealant around them, just be careful.
  • ward91
    ward91 Posts: 338
    edited June 2008
    +1
    take the drivers out, if no screw holes are visible they are often coverd up by grommets that hold the speaker grille on.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • paymontna
    edited June 2008
    Mission accomplished. I very carefully removed the tweet and the top driver. You almost have to remove the tweet to remove either of the drivers. After I removed the 9 screws, I used a thin metal washer to ever so slightly work the tweet loose. I got lucky; there was my little nut in plain sight. I did have to use a long screw driver and some patience because it was out of reach and I did no have a magnet that would fit inside. I now realize how well constructed these speakers are, and why they are so heavy.
    Pay
  • janmike
    janmike Posts: 6,146
    edited June 2008
    Job well done.
    Michael ;)
    NORTH of 60°
  • paymontna
    edited June 2008
    The nut in question was nowhere near the magnets and probably never would have come close, but I think I still could have shook the thing until my arms fell off and it still would have not come out. I do not even know how it got that far in with all of the insulation.
    Pay
