difference of monitor 50 and r50.
hdoggie24
hdoggie24 Posts: 40
edited June 2008 in Speakers
I have a polk rm10 satellite set. My receiver is 7.1 channel tho with running the rm10 set as 5.1. Would the monitor 50s work well with my system moving them to front l and r and moving the satellites to the surround back to have complete 7.1. Or how would the r50's work instead. Would these towers work well with my rm10 set or would it sound out of place. thanks
Post edited by hdoggie24 on
  • Kchill
    Kchill Posts: 262
    edited June 2008
    I would pick up the R50's, so in case it don't work you can use them in another room and be happy....I think you would be upset with the bass in the over all set up.
    Retired Onkyo 520 (returned broken HK 247)
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
    "Inch by inch lifes a cinch, yard by yard life is hard"
  • hdoggie24
    hdoggie24 Posts: 40
    edited June 2008
    i've got a 12" sub already so not worried about much bass.....what would be recommended for better front and left speakers for my setup. I don't need the best.
  • Meechsterlee
    Meechsterlee Posts: 73
    edited June 2008
    Have you considered a pair of RM30's or RM201's? I am thinking those are the perfect mates for the RM202 center that you have.
    Just me...I do not think that the Monitor 50's or R50's are going to compliment your front stage as good as you think.
    SAMSUNG HL-S42 DLP
    harman/kardon AVR225
    SONY PS3
    polkaudio RTi8's
    " CSi3
    " RTi6's
    Velodyne VRP1000
  • RutgersFTW
    RutgersFTW Posts: 458
    edited June 2008
    If you're concerned about a better music experience, a pair of Monitor floorstanders will probably be more satisfying than the RM10s (though I heard a set on the floor at Electronics-Expo and was SHOCKED at the clarity of the sats). However, the HT blending will be frustrating to impossible. You could lose the center and go phantom then use 4 satellites for surround and surround back.
    Currently listening to:
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Audio Technica AT-LP120
    Mirage CMD-5 x 5
    Bic H-100
  • hdoggie24
    hdoggie24 Posts: 40
    edited June 2008
    I am more concerned with movies for home theater and less for music. I like my setup but wanted to get a little more out of it. Would the rm30s sound good mentioned above. How much better are they than what i have. thanks for the help.
  • Meechsterlee
    edited June 2008
    The RM30 houses two 4 1/2" inch woofers and would be a great upgrade to your front stage...larger cab, slightly larger drivers, more punch than you are getting from current fronts.
    If the RM30 looks good to you, check out the RM40T's...seen some great prices on these, lately.
    SAMSUNG HL-S42 DLP
    SONY PS3
    polkaudio RTi8's
    " CSi3
    " RTi6's
    Velodyne VRP1000
  • hdoggie24
    hdoggie24 Posts: 40
    edited June 2008
    looked at the rm40t's. are these the same as the rm30s but just are towers. i am actually wanting to wall mount my speakers since i have small kids running around. will the rm30's and rm40's sound the same.
  • Frank840
    Frank840 Posts: 262
    edited June 2008
    buy a new center like the csi25 they go for 80 shipped all the time on ebay and. get the R50's.
    - This your Bush?
    Pioneer Elite Sc-25
    Polk Lsic,15's,9's, PSW1000
  • Meechsterlee
    edited June 2008
    hdoggie24 wrote: »
    Good idea to have these off the floor...nothing like coming into a room and finding a speaker lying on it's side.
    The 40's would be able to reach a bit lower than the 30's.
    SAMSUNG HL-S42 DLP
    SONY PS3
    polkaudio RTi8's
    " CSi3
    " RTi6's
    Velodyne VRP1000
