Monitor 10's fuse
edited June 2008 in Vintage Speakers
Just picked up a pair of monitor 10's with peerless tweeters last night. $75 on e-bay. Hooked them up and something was obviously not right. Neither tweeter was working. Both fuses were blown.
Will pick some up today, but wondering how frequently this happens? Should I get a large supply of fuses to have around or is it an uncommon event unless you're playing at excessive volumes?
Once they are working properly I'm anxious to compare the sound to my RTA-11t's which I have swapped the SL-2000 for the RD0-194 tweeters.
MWL
Post edited by mlastarza on
Welcome!
    edited June 2008
    The fuse holders get oxidized. just sand the fuse holder and all will be good.
    engtaz
    engtaz
    edited June 2008
    Thanks for the reply. Installed new fuses and all is well.
    MWL
    edited June 2008
    Make sure they are 1amp fast blow, or use caution.
    Ben
    Ben
Welcome!
Welcome!
